-   -   foam rubber material on firewall. (http://forums.pelicanparts.com/porsche-911-technical-forum/615979-foam-rubber-material-firewall.html)
PabloX 06-25-2011 06:47 PM
The sound deadening material on the firewall of my '86 has separated and is basically leaning on the airbox, etc.
Is there a standard fix for this? Removing the material and replacing it looks like quite a job.
Thanks and sorry if there's an existing thread on this. I searched but I'm not quite sure what to use for keywords.
Danny_Ocean 06-25-2011 07:03 PM
Search for "soundproofing". You'll find a hundred threads.
Kraftwerk 06-25-2011 07:39 PM
Pelican sells two different ones.... can be replaced. Much easier with the engine out, I hear.
PabloX 06-25-2011 08:23 PM
That's part of the problem. There are a hundred threads and most aren't applicable.
Similarly, I can't even find a thread on changing the oil
zippy_gg 06-25-2011 09:21 PM
No need to change the oil since these old cars just leak or burn about a quart/1000 miles. Just add when needed and voila!:D OK, not really...
The original soundproofing is bound to come unglued and disintegrate with age. As mentioned above there are a few replacement products to choose from.
You can call PP and ask about the ones they sell. They have excellent customer service and can give you some advice.
Danny_Ocean 06-25-2011 09:27 PM
Just searched "firewall soundproofing", fourth thread from top:
http://forums.pelicanparts.com/porsche-911-technical-forum/190877-engine-soundproofing-replacement-how.html
