foam rubber material on firewall.
The sound deadening material on the firewall of my '86 has separated and is basically leaning on the airbox, etc.
Is there a standard fix for this? Removing the material and replacing it looks like quite a job.
Thanks and sorry if there's an existing thread on this. I searched but I'm not quite sure what to use for keywords.
Old 06-25-2011, 06:47 PM
Danny_Ocean's Avatar
Search for "soundproofing". You'll find a hundred threads.
Old 06-25-2011, 07:03 PM
Kraftwerk's Avatar
Pelican sells two different ones.... can be replaced. Much easier with the engine out, I hear.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 06-25-2011, 07:39 PM
That's part of the problem. There are a hundred threads and most aren't applicable.
Similarly, I can't even find a thread on changing the oil
Old 06-25-2011, 08:23 PM
French Import
zippy_gg's Avatar
No need to change the oil since these old cars just leak or burn about a quart/1000 miles. Just add when needed and voila! OK, not really...
The original soundproofing is bound to come unglued and disintegrate with age. As mentioned above there are a few replacement products to choose from.
You can call PP and ask about the ones they sell. They have excellent customer service and can give you some advice.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-25-2011, 09:21 PM
Just searched "firewall soundproofing", fourth thread from top:
Engine Soundproofing Replacement..How-To?
Old 06-25-2011, 09:27 PM
