stud removal problem
hi everyone,
I have a friend that is removing dilavar head studs for me on 3.0. The broken one came out ok and the second one as well. now have trouble removing a couple. He is heating the stud and it is starting to twist, the loctite is not breaking free. Do we have to crack the case and drill out or is there something else we can try. thanks lou |
grab him quick before he compounds your problem! the case must be heated, NOT THE STUD! use an oxy/acetylene torch in the area IN THE CYLINDER BORE OF THE CASE, along the line that the stud threads would be. any other type of torch probably won't work.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-04-2002 at 04:24 PM.. |
thanks john
we will try this when we can borrow a oxy acetelene torch, I only have an acetelene tank lou |
Definetly do what John Walker has reccomended....
you have to use the oxy/Acetlyne and heat the case inside the cylinder spigot.... Do Not heat the stud..... There was a recent post in the last 6 weeks with pictures of where to heat the case.... just do a search
Senior Member
I tried propane for a very long time and barely got the area warm. You will need oly/acetylene. I also agree that you shoudl seach recent posts. John WAlker posted an awesome pic of exactly where to apply heat. Just as he said, after about 30 seconds of hot heat, you can feel the stud start to come loose. Keep heat on it as you turn it out, until you're sure it's gonna finish coming.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
joe
any idea of the title of the thread with the picture on where to heat the case cant find it and would like to print out the picture thanks lou |
I found the post guys
thanks lou |
