Max I have sent him one as well
Michael |
I would love a set of the rears also, but I hope he makes them for the Sway Away adjustable spring plates.
Clint has a GREAT product here - and just sooo damn beautiful! Wish more people in this industry would follow suit. |
He is also very impressed by your D-Zug 935 style chassis X brace. :) |
Rebel racing BUshings
YasiN: greetings. I am close to replacing my front 930 suspension bushings. Would you reccomend the Rebel racing set? What the main differences you've realized since instaltion? Is you car a street driver or a track car? What about road noise, any increase?
let me know please... Phillip |
Hope that helps. Good luck, it is conversion that requires patience and some time, but well worth it. Warm Regards - Yasin |
+1, I had them for about a year now and absolutely love them.
Agree, be patient while installing them and Clint is really helpfull. Before tearing things apart, make certain the new bolts will thread in, PO on my baby did a hack job and placed SAE instead of Metric but Clint helped me along. My understanding is noise will only be if installed incorrectly, i.e. binding and not dropping on it's own prior to torqueing the bolts with those eccentric washers. Remember once you find the sweet spot, you need to re-torque with the car on the ground tough if lowered but you can place her on ramps to do the same trick, the A-Arms need to be under load for this final stage of installtion. Agressive Street and occasional track/DE :D for fun and trying not be last Jim |
If you like his front RSR bearings, you should see the new rear springplate setup Clint has...... I saw them at Rennsport.
These will be going on my car shortly. http://forums.pelicanparts.com/uploa...1319389865.jpg |
Oh Snap!, Finally! He was there? damn missed him.
OK has anyone tried them yet? Quote:
He put the first set on his Mom's longhood a few weeks ago. That is the only car running them to my knowledge.
Guys,
If you are getting a "clunking noise" please closely inspect your spherical washers! They can be over-torqued and crack which caused the cluncking on mine......on the track! I used stainless versions for the fix. |
Clint is now supplying stainless washers. He had to have a batch made custom. The case-hardened ones are harder but also more brittle and can rust. They will work mechanically but the stainless are more painless to install.
Clunking noises can also result from a failure to follow step 7 or 11 or whatever it is where it says to tap the A-arm back snugly into the rear bushing, then tap the front housing back to take up all the axial play in the A-arm. Otherwise there will be a small amount of play that will result in a small clunk when reversing out of the garage. Once you start moving forward everything takes a set and is fine, even under braking.
I just got the Rebel S Racing (RSR) Products Front Bushing Set, Rebel S Racing (RSR) Products Rear Bushing Set and Rebel S Racing (RSR) Products Superior Quality Adjustable Bump Steer Kit with covers. I will post some pictures once installed.
Let me know how you like the rear bushings. Those are very new.
Just got my SS washers, Clint is the MAN! :cool: |
Has anyone had any experience installing the rear bushing set from Clint?
I helped Clint install them on my car. Some crash repair damage and other kuldges by previous mechanics made things a bit tricky on one side but other than that it was straightforward. I was switching from Delrin to them, so I was able to avoid the time spent removing the old rubber. It took Clint about 6 hours including getting the car in the air and also changing the torsion bars (and reindexing them) while we were at it. One side took about 5 hours and the second one only about 1 because it was nice and factory. Drove in in the morning and drove away in the afternoon.
Suspension Work June 2013 - a set on Flickr |
By dry-fitting to verify it will all line up, then disassembling, expoxying, and reassembling it all before the epoxy sets, you can be assured nothing sets up at the wrong angle. |
| All times are GMT -8. The time now is 08:19 AM. |
