Broken rocker or something worse?
How badly did I break my engine?
Was passing a car on the highway, took it a little into the redline but not much farther, and then started "clicking" or "tapping" a little under throttle. I thought it was maybe a broken exhaust flange or something as the car was still driving fine. After a few exits the sound got worse and by the time I pulled over it had a pretty bad knocking sound at idle. No smoke or oil, and the car still drive but was underpowered. I know it could be a lot of things and this is a fairly pointless thread, but being that it's a holiday and I cannot get the car into a shop to find out how bad it actually is, I'm hoping some people can give me some hope that I didn't bend my valves and have to rebuild or replace this engine for the 2nd time ![]() 3.0 euro SC engine with the big ports but lower compression. |
Doesn't cost anything to jack it up, pull the valve covers, and take a peek at the rockers.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Would love to do that but I'm 3 hours from my garage and the car is sitting in a random persons driveway until I can get a tow truck tomorrow.
Under the radar
Those motors are known to have valve spring failures and broken head studs.
Good idea parking it until you or your mechanic can determine the cause. Good luck.
Member 911 Anonymous
Hopefully this is all that happened
![]() ![]() Any obvious new oil leaks? Did it sound like this? ![]() ![]() This is what I found when I opened my lower valve cover ![]() Good excuse for me to upgrade my 3.2 to 964 Cams, in progress
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-04-2016 at 02:15 PM.. |
that's what I thought of.
I had a shaft come out. exhaust is worse than intake. seems like it is always the exhaust though. it is VERY loud
