My '74 coupe has a stock '75 CIS engine. On a fairly long trip using several tanks of gas I averaged 30.2 MPG at a constant 3000 RPM cruising speed.
Ordinarily, running around locally, I don't get anywhere near that much mileage, but then I don't cruise at 3000 RPM either. |
Current mixed back road driving is 23 mpg, but I've been a good boy compared to other years. Went from 15's 50 series summer tires to all-season 60 series, just not as much fun in the twisties anymore.:( |
I once got 32 mpg in my 87, but that was downhill coming out of the Rockies. I get about 27 on the highway if I can manage to keep it below 90 mph (not easy!!!)
Northern NJ to Eastern NC about 590 miles, I averaged 27 mpg.
I average about 19 mpg (4.5 liters)
Wow,
I try and keep pretty close tabs on the Targa, never worried to much about city mpg.....but I do watch the highway mpg just for fun. Pretty consistent on the highway, 75-90, cruising, 3 trips of around 250-300 miles....over 27mpg. No chip, no mods, and usually no top.....:>) Karl 88 Targa |
I have a 1980 SC and commute 20 miles each way for work....70% highway @60mph.
I keep my tires at 36psi in the rear and 34psi up front. I average 23.5 every tank. I also installed a heated O2 sensor, and manually adjust the control fuel pressure as it warms up. |
My 73.5 T CIS gets 28 mpg, loaded up with three people, luggage, going about 70-75.
It gets 24 mpg in my daily commute of 50 mph over the canyon and along PCH, with 10-15 minutes of stop and go. |
I can normally count on about 21-22 around town and maybe 27 on the open road/freeway in my 83sc 3.0; (190,000 on it) if I run around 3000-3200 rpm's @ about 72. Better with my 17" rims, less with my 16"; I run 34/36 on the 17" and 32/34 on the 16". But over the long run, it just seems to run up to 4000-6000 rpms all by it self on those country roads!
Enjoy every drop!!!!! art:D |
IMHO at "normal" cruising hiway speeds, say 60-70 mph, it is not possible to get 34 mpg in a 911.At that pace in my 85 3.2 Euro , I usually get about 24-27 (US, not Imperial). The speedo and odometer, oddly enough, are bang on. In my experience lots of full throttle action or higher cruising speeds will reduce economy significantly. In a day of Autox, including the drive to and from the event, I will usually get 12-15 mpg. Cheers
WOW - my 81 SC must have a problem. She runs great and has the mixture adjusted using an exhaust gas analyzer - 15 in town and 21 on the highway. So, that is that. I will say this, I have been in stop and go traffic with the outside air temp at 95degrees F and had no overheating problems. So, maybe, even though I had the mixture adjusted by a reputable shop - maybe I am running rich.
Just took a little family trip in my '81 last weekend, all highway speeds (75-80 MPH), windows down, sunroof open (AC deleted!). I calculated 23 MPG which was a little worse than expected, but not bad. My car is completely stock with a good O2 sensor, mixture set by me using an oscilloscope to monitor the test port (set to 50% average duty cycle). In town I probably average 16-17 MPG.
Is the steering a little jumpy at those pressures? |
Averaged 30 - 31 back and forth from Michigan to VA with the SC. Made the trip several times before SC metamorphosed into track car.
Current '99 996 w/3.6 gets ~ 26 - 28 on intersate trips. |
When I plan on doing a lot of back road driving I bring the pressure down. |
I average around 27mpg. Better than my 88 Civic that has a bad converter lock-up solenoid.:cool:
before i went to an adj. control pres. reg, my 75 with 3.0sc engine averaged around 24 on the hwy. when i went to the elec. wur., i could dail control press. up to 60lb on the hwy (15/1 afr) and now get 28-31 mpg on a reg. basis. to low control press (45-50) really effects mileage, but you wont really have any drivabilty probs, just not as good of mpg. get press. up to spec(55) and mileage will improve dramatically, as will performance.
I get around 25 mpg on the hwy with my all stock '77 2.7 doing averaging 70-75mph.
I get about 12 mpg on my carburated 3.2L , city driving. I guess that's expected for running on carburator ?
| All times are GMT -8. The time now is 06:24 AM. |
