Only checked it carefully one time. 1300 mile trip that was 95% Interstate and averaged about 65mph. Used GPS for mileage. 25.5 MPG. Totally stock 88 Carrera Cab with fresh oil and recent major service.
You do have to start with a full tank and refill the tank at the end of the trip to get any kind of accuracy. Fuel gauges are VERY approximate. |
While still jacking around with my jetting I'm getting around 17. However, I've noticed that there is a discrepancy between my GPS and speedo of about 3mph. I think if I do the next tank with GPS tracking I'll find it's a bit better.
I also hope it will improve when the jetting is perfect. I'd be happy with 25. We shall see. -Dan |
What is the RPM range for the best fuel saving? 2k-3k ?
-Andy |
My owner's manual says that the fuel mileage my '87 ROW Carrera shout get is 7.9 km/100 litres. This is equivalent to 29.7 US MPG. Mind you this is in just about perfect conditions, I would suspect.
The best fuel mileage I have ever gotten in my '87 is just over 29 US MPG. This was a 200 mile stretch of highway through the mountains from about 3800 feet to just above sea level. My speed ranged from about 60 - 85 MPH with an often heavy foot. I keep a spreadsheet of fuel fill ups and mileage. This measurement is consistent with previous fills, with similar usage, though somewhat higher this time. On a bit different note, a few months ago, I almost ran out of gas with some surging and sputtering rolling up to the pumps. With about a quarter tank since my last fill being used running around the city, I managed to drive almost 600 miles (964 km) if you take the odometer as being mostly correct. If one assumes the pumps as being accurate, I put in 86.8 litres of gas. In an 85 litre tank. I'm not sure how that works... |
My 911 got 26mph towing a small trailer......34 is doable with mild driving.
Paul Frere notes a record low for consumption with the 3.2L at 187g/hp/hour at 2,600 rpm.
I assume 5th gear on a level, at sea level, low weight, at 2,600 rpm with a new engine would be the max mpg...about 100kph with a euro car and G50.00. Frere 5th ed |
bingo!!! |
90% surface streets with plenty of stoplights, heavy right foot, frequent A/C use=17 mpg.
Once it cools off, I'd expect to see a 1-2 mpg improvement. |
I purchased my first 911sc in July, 2011. Drove it 473mi back home in Illinois. I got 27 mpg. I was very happy with this kind of mileage since I acquired the car without a PPI. It has 84,500 mi on the odometer.
On a trip up North in a 86 911 last week I decided to use the GPS. I was surprised to see about a 10mph difference between the 85 mph indicated on the speedo and the 75 mph showing on the Garmin. Thats more than 11% error in speed and in total miles traveled. More than enough to throw a fuel mileage calculation off by a lot. Too bad the Garmin doesn't show total miles driven. Len :) |
Just got back from a round trip to Beverly Ma. to get my daughter from college.
Filled up when i left.....refilled at same station. 326.5 miles /13.366 gal. = 24.43 MPG Mostly 68-70 MPH till i got near Boston then had to go 75 to stay with the flow of traffic.:rolleyes: Quite windy today....probably could have done better without the wind. |
ALL will start with you either Filling the tank to either the CLick of you see the Fuel at the top. EIther way you must do this the same way when refilling. You can either set the GPS of Trip Odemeter to 000 and start the trip. WHen time to fill up again, at the above person noted above write down the Number of gallons (Including the tenths) and divide the number of miles (Either the Odometer or the GPS) by the Number Gallons of Fuel and "THEN" you will know the answer. My 1976 2.7 on NON Ethanol gasoline got between 27 to 29 MPG depending on how much I was enjoying the car. Our 1982 3.2 with Ethanol (Read 10% Ethanol causes 10% LESS MPG) gets 25 to 27 MPG on the road. SO my answer is also NO you did not get 34 MPG! |
3200 RPM hwy cruising my 82 sc will get 32 mpg as verified by gps. Just lucky I guess?
If a 76 2.7 could get 29mpg under normal conditions, I'd think a 74 with less emissions could possibly get 34mpg with a tailwind and moving downmountain at a somewhat higher than sea level elevation.
For calculating fuel mileage, you must know the miles covered with a full tank of gas. I would think using a GPS is the most accurate way of measuring total distance traveled. My Garmin shows the rate of speed in mph, but how do I determine the distance driven? Of course, I never read the instructions, just plugged it in. Len |
| All times are GMT -8. The time now is 10:17 PM. |
