-   -   Where does this attach? (http://forums.pelicanparts.com/porsche-911-technical-forum/616306-where-does-attach.html)
megerian 06-27-2011 05:14 PM
I was poking around in the front luggage compartment, and found this. Being still fairly new to the car, and not finding anything in my various manuals (admittedly, I didn't look *that* hard, with so many experts here) I need to know, where should this black plastic piece attach?
http://forums.pelicanparts.com/uploa...1309219999.jpg
thanks!
sc_rufctr 06-27-2011 05:18 PM
I think that's the vent for the battery. The idea is to vent the fumes to the outside of the car.
The other end exits to the outside the body somewhere. Trace it back and see were it goes.
There should be a hole in the top cover of the battery that it plugs into.
Also....Check for any spilt acid around the bottom of the battery. Because that's not plugged into the battery top you may have lost some battery acid. :eek:
warner53 06-27-2011 05:20 PM
My guess is that it attaches to your headlight washer nozzle below your headlights.
Warner
nesslar 06-27-2011 05:32 PM
? Pretty cool, a vent for what is probably a sealed battery.... I think maybe warner53 is closer to the truth; looks like water piping to me....
megerian 06-27-2011 06:37 PM
I don't have a headlight washer nozzle
nesslar 06-27-2011 06:55 PM
Really? Maybe the previous owner changed out the bumper...? Just a thought. I would think '88s would have 'em as standard equipment....but I don't know...
dhagood 06-27-2011 07:13 PM
Warner
+1
sure looks like washer fluid plumbing, although the nozzle would have been on the other side of the front bulkhead (ie, outside the tub).
DRACO A5OG 06-27-2011 07:18 PM
Yeap, his garage shows the washer removed. SmileWavy
megerian 06-27-2011 08:44 PM
Hmm, I don't think it was removed, since there is no switch on the dashboard for a headlight washer, and there isn't any tubing going over to the right side where the other headlight would be.
rattlsnak 06-27-2011 10:01 PM
if you dont know what it is, dont lead someone down the wrong path.
it is a battery vent.
the headlight washer tubing is all outside of the car, none in the trunk area, and you can see the windshield pump in his photo.
megerian 06-28-2011 06:06 AM
So I looked around the battery, which is fairly new, and found no place for this to attach. My guess is that the PO replaced the battery, and seeing no place to attach this vent, just left it dangling.
Is there any concern about this? Can I just leave it this way?
Rot 911 06-28-2011 06:30 AM
Have you done this yet? If so, where does the other end of the tube go?
megerian 06-28-2011 07:36 AM
The other end of the tube, after about 6 inches, goes into a hole on the inside of the left front fender. So it can't be traced back very far. Maybe the issue here is that the newer battery either (A) does not require venting, so the tube is now unnecessary or (B) can be vented, but this connector did not fit.
rattlsnak 06-28-2011 08:59 AM
newer batteries vent through the top caps or out the top side IF at all.. (some have a 6" plastic tube running down the side)
in your case, answer: A
