Where does this attach?
I was poking around in the front luggage compartment, and found this. Being still fairly new to the car, and not finding anything in my various manuals (admittedly, I didn't look *that* hard, with so many experts here) I need to know, where should this black plastic piece attach?
![]() thanks!
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Almost Banned Once
I think that's the vent for the battery. The idea is to vent the fumes to the outside of the car.
The other end exits to the outside the body somewhere. Trace it back and see were it goes. There should be a hole in the top cover of the battery that it plugs into. Also....Check for any spilt acid around the bottom of the battery. Because that's not plugged into the battery top you may have lost some battery acid.
- Peter |
Wine User
My guess is that it attaches to your headlight washer nozzle below your headlights.
Warner |
Wash. State
I don't have a headlight washer nozzle
Wash. State
Really? Maybe the previous owner changed out the bumper...? Just a thought. I would think '88s would have 'em as standard equipment....but I don't know...
Eschews Obfuscation
sure looks like washer fluid plumbing, although the nozzle would have been on the other side of the front bulkhead (ie, outside the tub).
'84 Porsche 911 Targa '97 Ford F250 Heavy Duty '98 Volvo S70 '02 Subaru Forester '05 VW Passat TDI |
Member 911 Anonymous
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hmm, I don't think it was removed, since there is no switch on the dashboard for a headlight washer, and there isn't any tubing going over to the right side where the other headlight would be.
Insert Tag Line HERE.....
if you dont know what it is, dont lead someone down the wrong path.
it is a battery vent. the headlight washer tubing is all outside of the car, none in the trunk area, and you can see the windshield pump in his photo. |
So I looked around the battery, which is fairly new, and found no place for this to attach. My guess is that the PO replaced the battery, and seeing no place to attach this vent, just left it dangling.
Is there any concern about this? Can I just leave it this way?
Friend of Warren
Have you done this yet? If so, where does the other end of the tube go?
Kurt V No more Porsches, but a revolving number of motorcycles. |
The other end of the tube, after about 6 inches, goes into a hole on the inside of the left front fender. So it can't be traced back very far. Maybe the issue here is that the newer battery either (A) does not require venting, so the tube is now unnecessary or (B) can be vented, but this connector did not fit.
in your case, answer: A Last edited by rattlsnak; 06-28-2011 at 09:02 AM.. |
