DME Relay acting up....
Over the last few weeks the '86 Carrera has refused to start on 3 occassions, but then finally does start after a few minutes of trying. Tonight it refused to start at all, fortunately it was in the home garage. The fuel pump fuse was good, but I was not getting 12v at the fuel pump. Then I discovered I was not getting 12v to the input side of the fuse at the fuse panel. I removed the DME relay and smacked it around in my hand a few times, re-installed it and the car started right up. I suppose "no brainer", but does the relay gradually fail like this? Either way I am getting a new one tomorrow!
Thanks, Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
I had a problem that the pump would stop on a bump and got so it would not work at all. I opened the back of the connector for the relay and found the small black wire wasnt making good contact with the relay and was loose. I could fool with it when it was running but the small black wire needed to becompressed slightly so the contact would stay good.
Bruce |
Member 911 Anonymous
Yeap, the solder joints are probably cracked in the relay.
I would get two relay, one on stand by just incase you are out on the road.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Eschews Obfuscation
wut draco said, as having a spare DME relay is generally considered standard practice.
'84 Porsche 911 Targa '97 Ford F250 Heavy Duty '98 Volvo S70 '02 Subaru Forester '05 VW Passat TDI |
RETIRED
Cheap insurance.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
In addition to repairing cracked or broken solder joints I suggest to clean the pair of contacts within the DME. You never know if dirty contacts could contribute to the problem.
MikeD '87 930 |
