jmz jmz is online now
jmz's Avatar
Mechanical Speedo quit working and gearbox leaking oil Coincidence?l
I haven't had a chance to crawl under the car yet.
A couple weeks ago the speedo quit working. (1974 w/ mechanical speedo) and now the gearbox is dripping oil.
What should I look for on both to get this fixed?
THanks Pelicans!
JZ
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 08-04-2010, 02:29 PM
1966 - 912 - SOLD
lane912's Avatar
the right angle speedo cable driver that comes out of the transmition by the nose on the right side of car. most likely bad-
i was too tired to be pretty last night!
Old 08-04-2010, 02:37 PM
jmz's Avatar
lane, Do you think the two are related? ( the leak and the lack of a working speedo)
Old 08-04-2010, 02:49 PM
jmz's Avatar
Morning Bump
Old 08-05-2010, 06:49 AM
Mark S
Can't speak for lane but I do.
Old 08-05-2010, 07:10 AM
1966 - 912 - SOLD
lane912's Avatar
it was with my car, you can replace the right angle piece that comes out of the trans without pulling the trans. suport the nose of the trans with something and drop the front trans suport, have the replacement one ready because it will blead when you pull the bad one out.
Old 08-05-2010, 08:29 AM
Peter Zimmermann's Avatar
No angle drive on a '74 (915) trans (unless it's a Sportomatic). It's possible that somehow the cable came loose/broke at the nose of the trans, and the speedo drive seal has failed and is now leaking onto the ground, instead of into the cable.
Keep the Shiny Side UP!
Pete Z.
Old 08-05-2010, 10:32 AM
5String
Re the leak, the seal on the drive may be bad. Easy, but messy, to replace the seal, as when you pull the drive from the transmission housing, a great deal of the trans lube will escape. So have a large pan ready, as well as a new seal and some new lube. And yeah, it may be that the cable has broken. But you won't know until you get under there, unscrew the cable-housing retainer and look.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 08-05-2010, 10:53 AM
cnielsen's Avatar
Old thread I know.... I suspect my '74 915 has a broken speed drive as well. I checked the cable and it is fine. Also ruled out the speedometer itself. The '74 915 does not have a right angle speedo drive that is easily removable. I'm wondering if it can be replaced with the trans in the car?
TIA, Chris
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 06-30-2011, 07:22 AM
jmz's Avatar
My trans leak turned out to be the main seal leaking...
The speedo cable snapped about one inch behind the speedo. ...was just a coincidence. Oddly the Dam-n thing just broke again in about the same place. I think it only lasted about 6 weeks. I'm not sure if the speedo has an intermittent problem causing the cable failure or if there was a kink or something in the cable.
I don't know if you can fix the drive while in the car but I'd bet it is too tight to do so. ...maybe if you drop the cross member and support the trans some other way you might have some room to work.
Good Luck.
Old 06-30-2011, 07:38 AM
cnielsen's Avatar
I had the same problem on another car where I went through a couple speedo cables in a short period of time. Coincidentally, I had started rotating my speedometer for a "cooler" look. I guess this put a kink in the cable that it did not like. Once I moved the speedo back to the correct position, everything was fine.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 06-30-2011, 08:07 AM
jmz's Avatar
...I was kind of thinking this might have been the problem for me too. I had rotated the speedo so that I could see the 90-120 range (track use) which is blocked by the momo wheel if I don't. I really don't need to see the speedo so I'll just rotate it back to standard this time around.
Thanks!
Old 06-30-2011, 08:11 AM
cnielsen's Avatar
Good, hope that helps
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 06-30-2011, 08:22 AM
