I hate freight charges
Am I hurting myself?
Getting close to finished with my 4 year project and I'm installing a Carrera style oil cooler using factory hard lines.
What I don't have is an O.E. thermostat, but in lieu of that I do have a Mocal thermostat with -12 fittings. Is this going to be a problem/restriction in this system? Should I just go ahead and get one with -16 fittings. The car will be my weekend cruiser(no race track here). But I'm very leery of any temp related problems(traffic). Also, I have not added a fan, but may do so if the temps cannot be kept in check. Thanks!! ![]()
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
103 views and....................................crickets:co nfused:
RETIRED
Factory lines have metric fittings....you'll need adapters. Would suggest an oem thermostat.
Fans are for stop and go traffic and actually block cooling at high speed.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
MBruns for President
Do the factory thermostat. The Mocal does not have a pressure relief valve like the factory one has. It's not so much from the restriction - internally the factory thermostat does narrow down quite a bit in the internal passages.
If you've come this far - don't skimp here - especially if you are using the factory lines
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
porsher
I run my 86 in the desert on track, ambient up to 105F
my system can keep up with the heat load: AN12 fittings and hoses, center mounted cooler and carrera fender cooler, stock T stat. Not an exact match with your conditions but AN12 has been OK for me.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
BAT sells a Mocal set up for 911s that don't have the factory front cooler and it uses -12 fittings, I believe. So you should be fine.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Thanks guys!! I'll forge ahead with what I have for now, I'll pick up a factory t-stat soon. Maybe part of me doesn't want to finish this car that's why I'm nit-picking the last details
looking good there village ... it has been a pleasure to watch your journey .... enjoy
Aloha ... and maha'lo .......... Steve |
Insert Tag Line HERE.....
ive used the mocal t-stats in several cars over the years and never had an issue.
Steve, thanks for the encouraging words. It's been a long, long time coming
beautiful car!
76' 911s Signature Edition |
