what is this part
I am trying to figure out what part this is, I am looking at the rubber part next to the oil filler neck, it seems to be cracked but I cant figure out what part number it might be or if it is just a piece of rubber connector. Since it looks like it is about to fall apart I don't want to take it apart until I have the replacement.
http://forums.pelicanparts.com/uploa...1309534255.jpg |
Its the oil line breather hose I presume you are talking about
I guess that's what it is, I found the diagram looks like there is a rubber sleeve and a valve both NLA, is it an air check valve of some sort?
rubber sleeve 930 207 243 01 valve 930 207 229 00 |
Yes, a check valve to keep your idle up when you take off the oil cap to check oil level.
David,
I'm not at home to reference the part name or number, but I recently replaced that same part. You should be able to contact your nearest Porsche dealer and provide the part number. It is a special order part that will set you back about $15-$20 dollars. I ordered mine through a Porsche dealer in Phoenix. Hope this helps. |
| All times are GMT -8. The time now is 05:49 PM. |
