what is this part
I am trying to figure out what part this is, I am looking at the rubber part next to the oil filler neck, it seems to be cracked but I cant figure out what part number it might be or if it is just a piece of rubber connector. Since it looks like it is about to fall apart I don't want to take it apart until I have the replacement.
1989 Cabriolet
1970 911E Sold
Old 07-01-2011, 08:31 AM
twistoffat's Avatar
Its the oil line breather hose I presume you are talking about
Old 07-01-2011, 08:47 AM
I guess that's what it is, I found the diagram looks like there is a rubber sleeve and a valve both NLA, is it an air check valve of some sort?
rubber sleeve 930 207 243 01
valve 930 207 229 00
1989 Cabriolet
1970 911E Sold
Old 07-01-2011, 08:56 AM
sudo apt-get purge 930
equality72521's Avatar
Yes, a check valve to keep your idle up when you take off the oil cap to check oil level.
--clutch-monkey
Old 07-01-2011, 08:59 AM
muck-raker
kidrock's Avatar
David,
I'm not at home to reference the part name or number, but I recently replaced that same part. You should be able to contact your nearest Porsche dealer and provide the part number. It is a special order part that will set you back about $15-$20 dollars. I ordered mine through a Porsche dealer in Phoenix.
Hope this helps.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-01-2011, 10:42 PM
