2.2S Ignition Distributor on 3.0 w/ Carbs?
Hey all. I have a euro 3.0 (big valves) with 964 cams, 9.5:1 JE's, Zenith 40 tin's (34mm venturis) and a pre 74 exhaust.
My stock cis ignition distributor has issues and either needs to be rebuilt (and recurved) or replaced. I have the opportunity to purchase a 2.2s distributor and was wondering if this will be similar to one recurved for carbs. Thanks- Craig |
The 3.0 dizzy is completely different. It even turns the other way. You'll need to fix yours or buy another 3.0 dizzy.
-Andy
72 Carrera RS replica, Spec 911 racer |
Hi Craig,
I rebuild Bosch distributors. PM me if you decide to go that route.
Aaron. ![]() Burnham Performance https://www.instagram.com/burnhamperformance/ |
Call Barry Hershon.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Thread Tools | |
Rate This Thread | |
