Here is a pic of the shifter on my 79 SC. I am not sure if you can tell what kind it is from here? The shifter knob does NOT come off no matter how hard I try.
1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels |
Member 911 Anonymous
Looks like the OEM Shifter for 915 Trans. Maybe Factory Short Shift Kit???
Place wrench under the knob and use a mallet and hit firmly, becareful of your face or even the headliner so you won't dimple the finish on the outside. Do you have a pic of the knob?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
BTW, I have the factory short shift kit on my 3.2 and it looks just like it
It's a short shift kit, but I did not know they had factory ones? Was it an option you could pay for back in '79?
I think it was a recent upgrade maybe in the past 10 years. I don't recall PAG had this available in 79. Be happy.
Now to your knob in question, do you have a pic?
Hey Draco, here is a side pic and top pic of the knob. I was going to take it off to put the center console back in, and also was thinking of getting a wevo to cure my 2nd gear shifting difficulties. (though I've come to realize if I'm patient on the shift it's fine), but guess I should just stick with this one. I can twist the knob about 1/4 turn with my large rubber strap wrench, thats it.
It's a compression sleeve under the knob, that squeezes the shaft. Most guys get an open end wrench with an opening the size of the shaft, place it under the knob, whack upward with a hammer. They can be tough
David G PCA '72 S/T '74 Euro Carrera '95 RS --SOLD '77 930 Steel Slantnose "Wedgie" '57 Speedster planter Breeding family of Volvo/ BMW Wife + kid mobiles 'Rib-Breaker' '01 CRG 125 shifter kart Aprilia RS50-weedeater with fairing |
Hey guys what gives indication of factory short shift kit? I have 915 and it looks the same but the top plate with the lock out and flanges is broken in 1/2. The throw seems to be long already and I was hoping a factory kit would make the shift much shorter. I also have second gear issues with all new bushings. Seems to be sensitive to RPM and slop in shifter. Not hijackig your thread FGO just want to know what it is also.
Racer
No worries protex1. Were all on here to figure stuff out
