Swap a 91 G50 into a 87
Has anyone swapped a 91 G50 into a 1987 if so what did you have to do.
You need to change the nose cone to a G50 -01 style 87 thru 89. And shorten the shift linkage.
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Thats it nothing else
Formerly known as Syzygy
That's it? Hmmm, well, someone who knows, please correct this train of thought... Seeing that the 993 6-speed tranny is more or less a bolt in for a 964, and the 964 seems pretty much a bolt in for a G50 911, couldn't one assume that the 993 transmission is easily transplanted into the G50 911?
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Diss Member
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I believe he wants to install a 91 964 G50 not a six speed from a 993 ,
Sorry, my fault. I got a bit distracted and started in a different direction.
As it turns out, it wouldn't be as easy as I listed above - 6 gear is in the nose cone which would be switched to the g50-01 type.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 05-08-2012 at 09:35 PM.. |
Just the nose cone and shifting rod is different but just need to know what doto install in a 87
