electric help needed
I have a1970 911T, that I wanted to change out the batteries. I thought the old ones were weak and old, but with only the left battery connected I checked the amp draw and found it to be 5.5 amps!
I later tracked the draw down to the single red wire that goes to the back of the car and runs just about everything; alternator, ignition ecu, alternator ect. Other than disconnecting every item that is powered by a red wire one at a time, are there any short cuts that might help zero in on the culprit with less skinned knuckles and improvised curses. thanks john
sutton |
Fleabit peanut monkey
If you pull one fuse at a time you could possibly isolate the circuit.
did that. The large single red wire form the left battery runs to the hot side of the upper fuse block to 1 and 2. However 1 and 2 are ganged together prior to the fuse and run as constant hot to the stuff I mentioned. Pulling fuses won't help, I thought that someone might be able to figure which component might be the weak spot in a '70.
thanks tho sutton
sutton |
Sounds like you have a bad diode in the alternator.
Or possibly a bad regulator. Any draw over a few milliamps when sitting key off and no lights on is bad. You must track down the culprit. Bob
Bob Hutson |
Bob's right on track!! Unplug your VR and see if the drain goes away.. I don't remember if your car had a contact point VR.. It was very common in the 'day' for the contact points to stick together and cause a drain..
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Bob is right, that is a large draw so you can probably rule out something like a dome light. If not the alt. diode maybe the rear defroster; those use lots of juice.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Ok, guys, I'm officially stumped. Here is what I've disconnected both individually and altogether. the regulator, the alternator ( directly from the back of the alt.), both the cannon plugs that go into the console that holds the rear fuses ect; the and the rear heater element, cigar lighter and horn relay. I gotta hook them back up.
On top of that, the schematic that I have for a 1970 911 colored wires are different than the colors of the wires in my car. ( why would I be surprised) what would you check next because I still get a 6.65 amp draw when I hook up the ground wire from the battery in series to the chassis ground. thanks
sutton |
Member 911 Anonymous
Trunk and door switches are jimmied closed and clock fuse pulled, right? This what I would do on my 3.2
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
yep, clock disconnected and no lights on..........???
sutton |
If I may suggest, start pulling one fuse at a time to zero in on the offensive current draw. Slow but effective
![]() I don't think you have constant fuel pressue from your fuel pump like the 3.2. Try the fuse trick.
the draw of amps is from the hot side of the fuse number 1 and 2 which is ganged together. The draw is from the single red wire that comes off of the positive battery cable.
hope that helps.
sutton |
At one time from previous owner...alarm system installed?
If so...he may have "tapped" into the hot wire and bypassed the fuses...not correct...but some installers were lazy. You really need to pull the fuses to find out if the draw is going through one of them. Bob
Bob Hutson |
