davemccorkle's Avatar
Missing at low rpm's
Finally finished breaking in my new 2.7 RS configured engine. I do however have an annoyance and was wondering if you had any thoughts. When i start accelerating in 1st i always have a little missing until the rpm's get up. Once I am moving it runs like a dream. The other issue that i noticed is that every time i shut off the engine, like for gas or something and then start up again, it misses big time for about 15 seconds. This obviously seems to be a fuel issue but would love suggestions.
Old 05-22-2011, 04:47 PM
What kind of fuel system are you using? Carbs? MFI? CIS? Motronic? Other?
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 05-22-2011, 05:38 PM
Carbs
Old 05-22-2011, 05:39 PM
Pretty typical of a hot start, from my understanding. Valve adjustment may improve the hesitation.
Old 05-22-2011, 06:39 PM
It is like extra fuel needs to burn off before it can run correctly. It does happen ever time I stop and restart the engine that is hot.
Old 05-23-2011, 05:22 AM
2.7 RS configuration, webers carbs, holley fuel pump running about 4lbs pressure
Old 05-23-2011, 03:31 PM
No one has ever had this issue? I am guess it could be a jetting issue but I do not know what the sizes are yet without taking them out. That is my next step
Old 05-24-2011, 07:14 AM
nothing at all? hmmmmm
Old 05-26-2011, 06:08 PM
It is quite possible you may never get this resolved due to the new reformulated gasoline that was never designed to be fed into carburetors. High RVP's and high volatility of gas to meet smog may be the culprit.
Cheers,
Joe
Old 05-27-2011, 03:41 PM
never thought of that. sometimes it is the simple things
Old 05-30-2011, 12:30 PM
1QuickS's Avatar
Check accelerator pumps for equal output and check for blockage in all idle jets, one may be plugged but you haven't noticed the missing cylinder. If you have a check valve bleeding in your accelerator circuit then you won't get a full shot of gas to enrich during acceleration.
Sounds like heat soak of the fuel at your fuel stops causing some percolation. If your fuel bowls have crud in them or if they had pitting from previous corrosion then these will provide points for fuel to boil earlier than when the bowls are clean or smooth like when new.
Careful idle setup is vital: float levels set while engine idling, idle air balance (STE flow meter works very well) and idle mixture (I use a Colortune tool for idle mixture setting.)
Fuel pressure should be 3.5 psi, this is per Weber and OEM Porsche spec although 4.0 is probably OK.
2.7RS jetting is typically something like:
  • 34mm venturis
  • F3 emulsions
  • 145 mains
  • 180 air correctors
  • 60 idles
I assume your Webers are IDA, IDAP, IDS; not IDT, IDTP or IDTP1. The former have a richer progression than the latter.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 05-30-2011, 01:12 PM
Thanks a million! I will report back what i find.
Old 05-31-2011, 07:38 AM
I finally dug into the carbs and discovered that they are setup for a 2.0 not my 2.7 so I ordered all new jets, and emulsion tubes. I hope this takes care of the issue. I already had 34mm venturis
Old 07-09-2011, 02:37 PM
