Rough running 89 Carrera after being parked 6 months....possible cause?
After many years of never ever having an engine running issue, I started my 89 Carrera for the first time in about 6 months and while she fired right away....there's no power (I did not drive the car), the engine idles roughly and takes accelerator input poorly. Not the free revving I am used to. Never had an issue with this, so I am wondering? 6 months ago, plugs were changed, oil change, etc. and the car ran great. It's almost like it's only running on 3 cylinders...not sure.
The tank is about ¾ full. Battery was dead, new one installed tonight. So, any clues? Fuel, plugs fowled, ignition? What to check first? Any guidance would be appreciated! Thanks! Mike
VOPO '74 2.0 |
Driver
Gasoline isn't meant to sit around for 6 months. It separates, varnish develops on the fuel injection parts, etc. If everything else looks OK (battery, plugs, fuses/relays, etc) then see what happens if you drain out the tank and put in fresh fuel.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Detached Member
Cheap CA gas is my guess, lots of ethanol which evaporates and leaves gum. My Honda generator and my ECHO weed wacker suffer from the same affliction. Run it and dump some Techron in it. I "try" and at least start my Targa once every two weeks, whether I drive it or not, to at least run some fuel through it. Same with my RV.
But my 84 just failed SMOG as a GROSS POLLUTER, so I'm no expert.
Hugh Last edited by Hugh R; 09-29-2014 at 08:40 PM.. |
I'd drain the fuel tank and load fresh gas with a healthy dose of Techron or BG44k.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Straight shooter
6mos... Check for rodents. Otherwise top up the fuel. Next time parked more than 45 days you should put in gas stabilizer with a full tank of fuel.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Heck, I’m only 5 not 71!
Six months is plenty of time to build a nice home, have you checked your air intake?
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Ethanol....I had a similar issue, Added a bottle of redline SI-1 fuel system cleaner and it fixed her right up...plus its a upper cylinder lubricant so adding a little to each tank of gas will protect you against cheap gas.
I don't really believe that fuel goes bad within a year. I have had gas in my tank for much longer, and never had any issues. But maybe I am just lucky.
But I do agree with Noah's suggestion. Although, I don't think it was due to bad gas, rather, I think you got some water in your fuel due to condensation from temperature changes. But before I would go through all that trouble, pop the distributor cap and make sure everything is dry in there. You may get lucky.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
injectors may be stuck
Rick 88 Cab |
Straight shooter
^x2
If you have an infrared thermometer then you could check each exhaust runner. Find a cold cylinder, check the spark plug. If it's stuck then you can lightly tap on the body with the engine idling which sometimes can un-stick them. Probably a good idea in that situation to run injector cleaner through... Techron, Lucas, STP, Marvel etc. Choose your snake oil wisely.
Flat Six
BTW, when the local refineries slow down/shut down 2X a year to switch processing from one formulation to the other, there's a 'temporary' price hike attributed to restricted supply that somehow magically becomes a permanent price increase.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Flat Six, you make a good point. The gas in my car was purchased in the summer, so the blend was different.
Thanks so much for the input. And you make me laugh when you call California the "People's Republic". You need to come visit Pennsylvania one day. It is almost mandatory that you carry a firearm. Not too many gun laws here, LOL. Quote:
Flat Six
I did not realize you even reformulate in California so i thought that was not it .. the sticking injector makes sens though as the stuff in the tip of the injector can gum up after that long.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Lots of people insist that there is nothing wrong with gas after 6 months. In fact lots of people claim not to have suffered any ill effect with storing an engine without stabilizing the fuel, BUT:
Open up a carb that has been put away wet and has had the fuel evaporate, and see what you see in the float bowls! Anytime I park for a month or more I add stabile or similar product to the tank, and run it long enough to have the mix make its way to the combustion chamber. Otherwise untreated fuel sits in the carb or injectors, causing sticking. Eventually it happens. Each season may close off your orifices just a little bit more. Drain it (the floats) or bleed it (the injection system) or treat it before parking it. I am less concerned about the gas in the tank since there is such huge volume in comparison to the flats or injectors, although why not just treat it to be safe? (if that is the cause, you may get lucky by just running a few tanks of high test fuel through it since they are supposed to have some detergents in the ingredients).
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 09-30-2014 at 11:54 AM.. |
Still here
I'm no chemist but I would think gas can be left sitting longer in a mild climate area like California vs Canada.
Fleabit peanut monkey
Winter gas has more VOC's - Volatile Organic Compounds - It turns to vapor more easily so your engine can pop better on a cold-ass day. If you hypothetically filled your tank in the summer with winter gas the vapors exiting from the tank on fill up would be way more than less volatile summer gas. For the chemists, the term is RVP - Reid Vapor Pressure. Some kind of test where they measure the VOC's. So the gas will have an RVP of XX.
1981 911SC Targa |
