dshepp806's Avatar
1989---rear sway bar fracture
Just a reference (hope it's ok) to another thread regarding sway bar fracture,..I feel better knowing it's quite common and there appear to be great, solid fixes for this...anyone who's "been there",..(?) I'd certainly appreciate all input, as I'd like this to be done properly.
thread: 1989-sway bar mount separation,..aarrgghhh - Rennlist Discussion Forums
Thanks!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-09-2011, 10:19 AM
steely's Avatar
Am following this as I understand this is a 'feature".
I've been refreshing this and that over the short time I have owned her, and was planning to do the rear suspension this winter (TB & sway bushings, not the TBs unless I needed to, and not the trailing arm bushings, but yes to the drop links).
I am wondering if I should pre-emptively do what you are now looking at.
Sorry for barging in - and good luck Doyle. Don't fret, she'll be right as rain in no time.
May I ask how you discovered it - through change in response or just a routine inspection?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-09-2011, 11:50 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey Doyle,
If Stock Suspension, the OEM mounts should be just fine.
If one upgrades to larger sway bar or even raise or lower beyond OEM spec, it will definitely stress out the mounts and potential breakage.
To take preventative measures, in addition to lowereing, corner balance, and larger sway bars, I also upgraded to larger OD Torsion Bars to take the load off the sway bar.
Been doing the occasional D.E. and AX events with no issues. I always keep a close I eye those mounts. If they ever break, I will upgrade them when needed. I feel very confident they will hold up.
Jim
'85 Carrera Targa
PCA/POC
Old 07-09-2011, 12:28 PM
Mine broke on the passenger side years ago...repaired in Denver by Carquip...IIRC about $100.00 labor. Been solid for years now.
1986 3.2 Carrera
Old 07-09-2011, 12:31 PM
Northern Motorhead
wildcat077's Avatar
Doyle,
A track buddy of mine tore both his mounts off last month on his stock 88 Coupe and he gave me a heads up and after checking mine i discovered the left rear was starting to tear...
I welded it back but i have to check them after every event.He had the Wevo brackets installed by a shop and it cost him pretty close to $600.00 dollars with the new bushings and alll, although those things look pretty much unbreakable.If i manage to finish the DE season unscathed i will definitely be welding the Wevo mounts on my car over the Winter.
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-09-2011, 01:21 PM
moneymanager's Avatar
It's not the bar which fractures but the mounts as you know.
Fixes are easy; easier if you do them before you have the problem. Easiest thing to do is to reinforce the existing mount. Did mine years ago, $75 worth of welding I think, and they have been fine. This on a car which gets heavy track use. If they tear off, you're into Wevo or another more expensive fix.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-09-2011, 01:50 PM
DRACO A5OG's Avatar
Hey MM, where did you get the reinforcing done, did you have to remove the sway bar? I assume yes to save the bushings
'85 Carrera Targa
PCA/POC
Old 07-09-2011, 01:57 PM
My mechanic here in SB did it. Any decent independent Porsche shop or welder should be able to handle it. You just "box" the stock mount a bit to increase its strength. Toss the bushings if they're a few years old, but if they are new you just loosen and drop the bar (with the bushing and the clamp) and weld. Careful of the fuel lines and pump if they are nearby; they were on my car.
jhtaylor
santa barbara
Old 07-09-2011, 02:10 PM
DRACO A5OG's Avatar
Cool, I may reinforce just in case
'85 Carrera Targa
PCA/POC
Old 07-09-2011, 02:37 PM
Diss Member
Quicksilver's Avatar
There is no reason to replace it with the "beefed up" stock repair piece. Those fail too.
Get the WEVO RARB console: http://www.wevo.com/Products/ChassisProducts/WevoChassisProducts-RARBConsoles.htm
Fix it once and be done with it.
My rear sway mount failed a few months after I bought my car (all stock suspension) and I drove it for about a month before I had time to get it welded. It would pickup the inside front tire a few inches in a corner. Pretty funny. I did one Auto-X without the rear sway and I had everyone's attention.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-09-2011, 06:14 PM
dshepp806's Avatar
QS: that's the very part mentioned, to install,..and will be my route.
Thanks,
Doyle
Middle Georgia
Old 07-09-2011, 06:53 PM
