2nd day on the road and my '86 Carrera left me stranded.
I went to my dad's for a bit this afternoon. I got about a mile from his house and the engine quit right in front of a Catholic church and I was able to coast into the parking lot. Certainly some sort of sign and surprisingly, I wasn't inspired to let loose with a litany profanities.
I'm 99% sure it's the fuel pump. I used my dad's AAA to get it towed to my house and it's already up on jack stands.
Old 07-02-2011, 04:58 PM
Do you have a spare DME relay?
Do you want to McGuyver it and try jumpers?
DME Relay - from "The 944 Motronic DME" by FR Wilk
Rick
88 Cab
Old 07-02-2011, 05:04 PM
Hmm, I don't have a spare one, though I should probably order a couple (are the Kaehler ones ok?). I can certainly do a bit of diagnostic with a multi meter.
If it is the DME relay, it's totally dead which seems to be somewhat unusual based on what I've read. The engine chugged a bit and then died while I was on the road. I coasted in and the engine caught twice and ran for a second or two each time, then that was it.
I'll probably order the relay, fuel pump, check valve and a new fuel filter and just replace them until the car fires. It'd be good to have the spare parts on hand anyway.
Old 07-02-2011, 05:38 PM
If you don't have a spare relay you should go to the standard troubleshooting steps.
Spark
Fuel -- does it run for a sec on starting fluid.
If you suspect the fuel pump you can jumper the fuse in front and hear fuel squirting through the regulator in back
Edit: did I mention spark is an important thing to verify?
Edit: Edit: As in if you get a regular spark all the DME sensots are working.
Rick
88 Cab
Old 07-02-2011, 05:58 PM
Member 911 Anonymous
DRACO A5OG's Avatar
When the DME relay dies, it dies. Try tapping on it while trying to crank it over. The solder joints maybe cracked.
But +1 you need a spare relay regardless & check above as indidcated^^^
'85 Carrera Targa
PCA/POC
Old 07-02-2011, 07:09 PM
scottb's Avatar
Two thoughts --
Is your battery dead? If so, then it's likely your alternator. My 84 behaved exactly the same way as you described when my alternator went bad.
If your battery is still good, then the first thing I'd check is the DME relay.
1984 Targa
Old 07-02-2011, 11:26 PM
Eschews Obfuscation
dhagood's Avatar
is your charging light illuminated when the ignition is on and the car's not running? if so, your alternator is most likely not charging.
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 07-02-2011, 11:48 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
If it turns over the battery and alterantor are good. Next, check with a new DME relay. If that is bad the fuel pump shuts down. Once a new DME relay doesn't fix it you need to check whether fuel, spark or both are missing when cranking. This will help differentiate between DME, coil, sensors, etc.
ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-03-2011, 04:29 AM
Wash. State
nesslar's Avatar
"(are the Kaehler ones ok?)" Kaehler DMEs are rated at 30 amps, I believe, as opposed to 15 amps for the originals. Should make them tougher, no? I mean, the connections/solder joints are "beefier" I imagine.
Old 07-03-2011, 09:56 AM
DRACO A5OG's Avatar
As I recall from previous threads, higher amp relay may cause connected component/s i.e. wiring or worse the DME to over load/ burn out. Relay is much cheaper to replace then the DME or for that matter the wiring loom/harness $1300
Liken to putting 30amp fuse on a a 25 amp fuse that keeps blowing. Defeating the designed purpose of the fuse.
my 2 cents,
Jim
'85 Carrera Targa
PCA/POC
Old 07-03-2011, 10:45 AM
brads911sc's Avatar
Agree.
By the correct relay at the correct amperage. I would not use one rated double the amperage. You are just asking for trouble if you have other issues...
my 2 cents,
Jim
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 07-03-2011, 11:03 AM
Wash. State
nesslar's Avatar
Yep, I hear ya, but it's only "a rating", doesn't draw any more juice than the OEM relay, and should (must) still of course be protected by the "stock" (proper) fuse. It's just a "sturdier" relay, I'm sure, assuming the rating is accurate, and would probably last much longer (in theory).
It's like a 200 amp house/commercial electrical panel vs. a 225 amp panel; stronger/heavier bussing in the 225, i.e., thicker copper or aluminum "bars" to connect various circuits to. If each panel is loaded to say 150 amps, same items/circuits, with everthing connected "turned on", no diff. in performance. Many more dollars for the 225....
Old 07-03-2011, 11:06 AM
I realize this is a German car we're talking about, but if the system was really designed to have the relay double as a fuse, that's pretty horrifying from an electrical engineering standpoint.
Old 07-03-2011, 11:17 AM
Formerly known as Syzygy
Canada Kev's Avatar
You mean like all the unfused circuits in these cars...?
+1 on all the stuff listed, and get yourself a couple DME relays, even if it turns out not to be the problem. Good luck.
Kevin
Old 07-03-2011, 12:10 PM
You guys are writing way too much into this relay thing.
Rick
88 Cab
Old 07-03-2011, 12:50 PM
dshepp806's Avatar
What relay "doubles as a fuse"?
Higher "ratings" mean (only) beefier material(s).....little to do with "current draw"...
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-03-2011, 02:14 PM
Best!
Doyle
I was referring to the person who stated that a relay that handles higher current could allow something downstream to get damaged, like the lower amp relay is acting to protect the DME.
Maybe I missed the point of what he was saying but I'm not worried about a higher rated relay in any event.
Old 07-03-2011, 06:37 PM
DRACO A5OG's Avatar
Actually, if I may, the DME relay does not blow like a fuse. it usually fails due to fractures of the solder joints inside.
If heavier component would include hefty does of solder then maybe, I say maybe it might be OK but I still default to not putting a higher amp relay.
My 2 cents.
'85 Carrera Targa
PCA/POC
Old 07-03-2011, 06:42 PM
I just placed an order for two DME relays and a fuel pump.
The DME relay that's in the car says "made in West Germany" so it's probably the original and that'll be my first try. I'm thinking of replacing the fuel pump even if the relay does fix it, just because.
Old 07-03-2011, 06:51 PM
DRACO A5OG's Avatar
Best wishes on the relay, Brother!
How many miles do you have on your Fuel Pump? They are supposed to be good fro about 100K miles. I believe I am on my second and I have 230K miles so I may be due soon.
Hey I think we just Hi-jacked your thread
'85 Carrera Targa
PCA/POC
Old 07-03-2011, 07:22 PM
