84-86 and 84-87 motronic questions
Hello- I have bought an 89 engine for a learning project this winter. When that phase is done- I will look for a roller for it. I understand that the 87-89 engines with G50 trans used a particular flywheel and sensor arrangement, and that the 84-86 engines with 915 trans used a different system. My questions are: can you plug the 89 engine to an 84-86 trans and clutch? Is the sensor different? Which DME to use, or does it matter? Thanks in advance!
The sensors and electrical connections are the same across all 3.2. The only difference is the idle speed. Later 3.2 have slighly higher idle speed and the intake need to be adjusted accordingly.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Eschews Obfuscation
is there a flywheel difference between the G50 and 915 carreras?
'84 Porsche 911 Targa '97 Ford F250 Heavy Duty '98 Volvo S70 '02 Subaru Forester '05 VW Passat TDI |
INGO: "adjusted intake", meaning "idle"? (RPM)
Thanks! BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Once you pull the bell housing studs, the short G50 stud is right to put where the long one is for the 915. You need a flywheel, and clutch package, 3 short bell studs and everything is the same.
The brains are different but the harnesses are the same but the 89 will bolt right in and will run when properly installed. Bruce |
Burn the fire.
There are also differences in the DME...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Member 911 Anonymous
OEM chip setup is different but will still work. Only 2K vs 4K chip set up, 84 is soldered 85-86 are not. OEM 84-86 it will idle at 780 vs 880RPMs
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
