Member 911 Anonymous
CAT/PRE-MUFF Thermal Wrap, Anyone???
I want to reduce the heat emitting from my pre-muffler.
Has anyone did this? Pics & Hints please ![]() Is there a neg side effect in thermal wrapping? Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
oe of the negative, from old time was water trap in the wrap and rust the component (header and such). Now it's all ss, I am not sure if it's still applied.
Fat butt 911, 1987 |
Cool, well my M&K is SS so no issues there
I wrapped, so far no issues but looks like rust is forming under, I wanted to keep heat off the engine, tire and shock.
Do you have the OEM Cat?
RETIRED
Best to use a heat shield....wrap will suck up oil and water.....you may have s/s tubing but are your nuts and bolts?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Checked out
the heat from a premuffler is insignificant. I wouldn't bother with any kind of wrap, it won't do any good for anything.
abit off center
Well placed heat shields
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I do have the OEM Cat Shield, Maybe I give that a try first.
M, yeap bolts & nuts not SS, good catch Master M ![]()
another good option would be two have it thermal coated.
On my previous wrx i put a more smoothed out transition pipe (crosspipe) between my two exhaust manifolds that seemed to help quite a bit but, removing the factory crosspipe left me with no protection from and to avoid the heat soak i opted to have the new pipe thermal coated. now that i think about it would us non-header guys with heat exchangers and the crosspipe from left to right banks see any performance gains with a new crosspipe? sorry for the hi-jack.
Ryan- Sad day when my 83 911 left me ![]() |
What if I just wrap the main body and avoid any non SS components? Better than nothing right?
Pre Registered
Tim |
Okay Okay, You Guys, Geez the Peer Pressure is a Killer, Dang
![]() Well, thermal paint, what was that JB, Jet something???
RETIRED
OMG Sterling, that is Freakin Beautiful!
Not sure I agree with this. The stock cat setup has a very well designed heat shield that is installed with it. With a test pipe (no shield) the distance from the pipe to the shock and tire are about 2" or less, if I remember correctly, get that pipe red hot and then stop e.g. at a stop light and you have some very hot surfaces near these items. I have no temp. measurements but that's why I put wrap on.
RETIRED
From the Hon-duh Board.....
HowTo: DIY Exhaust Coating - Honda-Tech
Checked out
If your car is getting a test pipe "red hot" then you have a serious tuning issue. It's a nonexistent problem. SCs and Carreras have been running around safely for 22-34 years now without any heat related problems from the cats (certainly, your shock absorber and tire do not need to be shielded from the cat), and with the original poster's test pipe, it will run significantly more cool than the cat. |
please give me a few days to provide a picture of the cat heat shield found on my 89, in the absence of measurements or other data I propose we agree on a dead lock consisting of conflicting anecdotal info.
