rear stabilizer bracket
While in the process of removing my engine and trans I found this...any thoughts on a repair procedure? I could not find that Pelican sells this part...can this be welded?
"Charlie don't surf!" |
porsher
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Does that replacement part get welded on after removing all traces of the previous one?
porsher
Correct. Grind it clean and then place the bracket.
Do a search for wevo bracket and I'm sure you will find how to do it info A great, while-the-engine-is-out job!
Northern Motorhead
Same thing happened to one of my DE track buddies on his 88 Carrera last month ...
He purchased the Wevo brackets from Pelican and had them welded on ! Have to admit,those brackets look indestructable ... Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
