gas tank drain
I have a 1980 911 and need to drain the gas tank.Does any one know the size of the gas tank drain, the allen wrench size in mm.
Old 07-12-2011, 06:42 PM
Member 911 Anonymous
DRACO A5OG's Avatar
How about just disconnecting the fuel pump hose?
Sorry do not know the size of the drain nut
'85 Carrera Targa
PCA/POC
Old 07-12-2011, 07:01 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I'd like to drain my tank...
Old 07-12-2011, 07:20 PM
22 mm allen wrench substitute.......
Boydskyking,
You need a 22 mm allen wrench or do what I did. Get a 7/8" bolt and 2 nuts as an alternative tool. A 7/8" bolt has a head that measures almost 22 mm. See pictures below.
Tony
Tsunamiboy's Avatar
Take your spark plug socket and insert a ratchet extension in the business end of the socket attach your ratchet and use the top of the spark plug socket to remove the gas tank plug (drain the gas out first ;-)
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 07-12-2011, 07:34 PM
gas tank drain
Thanks guys
Old 07-13-2011, 05:30 AM
scotricker's Avatar
get a new gasket for the strainer assembly first.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 07-13-2011, 08:30 AM
Somewhere in the Midwest
MotoSook's Avatar
I highly recommend you pump out the fuel before you take the strainer out. No matter how little gas you have in the tank, you will get a lot more than you think you have.
If I recall correctly, a 3/4" wrench extention fits perfectly. Use a combination of sockets and racket to get it off. I just did this recently for a friend. Or you can doubke nut a 22mm bokt head like above, but if that strainer is in tight, you'll just spring the nuts. The new strainer should come with a seal...
Old 07-13-2011, 08:59 AM
