I know something happens in 28 days.... |
11 days since your last post. ;)
I am waiting for a new Pertronix II ignitor and trying to decide if I am going to install the later model RS door panels you lent me or just bite the bullet and get the early style RS door panels in vinyl from AppBiz/Pelican (which is what I want). |
Combatic,
I was searching for seam sealer and ran across your posts. I am in the process of fixing my 71 911T and have a leaky acid battery issue. The acid ate away a portion of the gas tank lateral support. I noticed on your 1st picture on this thread that you replaced the front foot or so of the support. Where did you aquire the support, or did you fabricate? Hopefully you will get this message. If so, what seam sealer are you using? Thanks Bob |
Any updates?
Also, you don't happen to work in Bellevue do you?
Day 1010 | Behr Oil Cooler Removal + Suspension/Brake Upgrades
3/10/2014 Project 1 | 2.7 Behr Oil Cooler Removal After driving the car for a couple of years and putting up with the oil flavored heat coming off of the SSI’s, I have decided to try and tackle what I believe to be the main offender, the behr oil cooler on my 1977 2.7L in my 1969T. https://lh4.googleusercontent.com/-t...210147_999.jpg I was told that you CAN remove the oil cooler without a motor drop and I am happy to say that in a couple of hours I was able to remove it with minimal trouble. The heater will come out the side with the wheel removed and by dropping and tilting the motor down slightly. https://lh6.googleusercontent.com/-L...225355_430.jpg Project Prep. Get the car up in the air, drain oil & remove right rear wheel. Prepare catches and rags for oil dripping everywhere, crank the tunes, open PBR & dig out your 10mm, 14mm & 19mm sockets, various extensions, and drop lights. Step 1a | undo oil feed & supply hoses from the oil tank, rotate them down and drain remaining oil from the oil cooler then remove hoses. https://lh3.googleusercontent.com/-f...210241_863.jpg Step 1b | remove duct from the top of the cooler https://lh4.googleusercontent.com/-5...200937_864.jpg https://lh6.googleusercontent.com/-e...200753_340.jpg Step 2 | Remove tins blocking AND bolted to oil cooler. Before removing the tin, remove SSI heater intake hose passing through tin FIRST (I couldn’t get to one of the 10mm tin bolts b/c it was blocked by an oil line so removing the hose makes the tray tin removal possible). Step 3 | Unbolt hard oil return line from oil cooler and tie back so that the bracket clears the cooler (I used the shock. Remember this is for a mid year 2.7 so ymmv) Step 4 | Unbolt the 4 nuts holding the cooler on. (You will need long extensions to clear the SSI’s) for this one. https://lh4.googleusercontent.com/-E...210211_711.jpg Step 5 | Partially drop the motor. This allows the cooler to slide out the side clearing the SSI’s and the car body. (make sure you support the motor! I don’t want anyone accidentally dropping a motor!!) https://lh3.googleusercontent.com/-7...223006_552.jpg Step 6 | Remove oil cooler & seals. Replace with your clean, pressure tested replacement cooler. https://lh4.googleusercontent.com/-X....jpg[/url]https://lh4.googleusercontent.com/-X...223134_712.jpg ...now I just have to find a cooler and seals ;) |
Day 1010 | Behr Oil Cooler Removal + Suspension/Brake Upgrades (cont.)
3/10/2014 Project List 1. Upgrade stock front M brakes and solid rotors 2. Upgrade front Boge Struts 3. Replace front and rear suspension bushings 4. Add swaybars Goals- The car has been developed from day one of restoration to be a sports purpose touring & track weapon. This means reasonable weight reduction (reasonable to me is avoiding the slippery uber dollar slope to shave ounces), aggressive suspension (currently running 22/28 T-bars) but with enough compliance to handle uneven surfaces and terrain encountered up in the mountains. Brakes should work cold but never encounter fade during aggressive driving during touring or DE days. Phase 1 | Front Struts & Brakes Stock OEM setup still on the car https://lh4.googleusercontent.com/-7...224426_998.jpg Parts acquired & ready for restoration. Wide A Carrera Brakes & 24mm vented rotors (used from 84-89) and Boge Struts with Koni Inserts & 3.5” brake mount spacing (This is important b/c the stock Boges on the car only have 3” spacing and limits brake options to the stock ‘M’ Ate’s & pad sizes and I think rotor types. In my case I am opting for the wide A Carrera brakes and rotors that will still fit under my 15” deep 6 Fuchs) https://lh4.googleusercontent.com/-U...170005_183.jpg Resto Begins https://lh5.googleusercontent.com/-z...172912_898.jpg https://lh6.googleusercontent.com/-Q...173306_358.jpg https://lh3.googleusercontent.com/-Q...172008_521.jpg |
When I upgraded my '69T to 3.5" struts I also had to change the bottom ball joint & securing tapered pin to the slightly later '72 - '89 style.
Our hosts list them & have a helpful tech article although I suspect with your abilities you might not need to read that ;) |
Martin, thanks for the heads up! The ball joints were not on my radar and need to be added to my parts list! The pelican articles are always a good read. Cheers!
Bryan, I have several recently refurbished oil coolers if you want one to exchange while you are getting yours cleaned.
oil coller!
make sure to seal this! http://forums.pelicanparts.com/uploa...1394550640.jpg http://forums.pelicanparts.com/uploa...1394550678.jpg |
Flo, thank you for sharing the technical bulletin. As usual the help here on Pelican has been exceptional! Danke schön!
Well, I got that help myself from here a couple of days ago. So I pass it on ;-)
Pelikan rulez! PS... whats that lovely vintage blue color called? if it was a benz, I'd guess it to be "chinablue" (China-Blau). PPS... an waht a great work on your car! i envy your garage and new lift! |
any update?
Anything new? I keep coming back to check on the car.
I know it's highly unlikely but if you ever part ways with it please contact me first. I'd love to get it back in the family if you decide so. Great work! |
Been a long time. Hoping for an update.
Does anyone know what's happened to Papa Smurf? Haven't seen an update in years. If combatic ever lets it go I'd love the first chance to get it back in the family.
Not sure if Bryan is on Pelican much anymore. He is still driving “Papa Smurf” often and thoroughly enjoying the car.
RIP Marc |
Ultimately I had to choose between the car and my brothers boys but it kills me I had to let the car go (it's a long story). If anyone has Bryan's contact information please let me know via PM. I'd like to just be in line if he lets it go. Todd |
This is another incredible build since I've joined this forum. I'm getting very motivated to start posting my build.
| All times are GMT -8. The time now is 01:55 PM. |
