Follow me
seymore's Avatar
Does $4250 in labor sound right?
New shocks, ball joints, tie rods, sway bar bushings, Valve adj with new spark plugs, SSI's, M&K muffler, Lowering and repositioning torsion bars for $4250 plus tax.
I Bought all parts thats just labor.
Is this a good deal?
Thanks for your input.
1982 911SC
Old 06-01-2011, 11:45 AM
Diss Member
Quicksilver's Avatar
Sounds rather high. That just isn't that much work. Not sure if DC is just one of those places where prices are through the moon but I would think that you could get this done for less then $2500 at a lot of good shops.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-01-2011, 11:50 AM
Vintage914Racer's Avatar
I'm no expert, but that seems steep to me. Assuming $100+/- labor rate, that comes out to 42 hours of labor. I am a slow worker, but I would like to think I could get it all done in a few 8 hours days.
If I'm delusional please let me know.
FinallyGotOne's Avatar
NO. I do not think that is right, too high. I paid about $1300 I think for the labor on my exhaust swap from stock to a 74 OEM set up. I paid 450 to lower and have it realigned, Valve Adjustment was about $400. I replaced the struts up fron myself and it took me about 45 minutes or so each side. My guess is all of the work should be about $3500.
My opinion, I'm not a shop tho...
French Import
zippy_gg's Avatar
If you do the math that is 42.5 hours @ $100/hour, or a week worth of labor.
That sounds more like my speed as I am not a pro and do not possess all the tools.
I am doing slowly what you had done to your car, and my Carrera is not my primary transportation. Then again I like doing that $h1t...
The money saved on labor is used to buy parts...
Was you labor bill a good deal depends on how much you value your free time, like to do your own wrenching, or are in a hurry; very subjective.
For me personally I'd say it is high, but YMMV.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-01-2011, 11:55 AM
user & abuser
I just had an oil change, + inspection, ball joints, turbo-tie rods, Lowering and repositioning torsion bars, corner balance (x3) and a couple of different alignment setups (with me seeing in-between) performed for for roughly$1500CDN including parts, labour and tax. They also washed and vacuumed the car.
Major props to Bernie and MB Euroworks in Vancouver - everything seems absolutely top notch, communication, time, quality, the shop cleanliness.
vini vidi vici
Old 06-01-2011, 12:04 PM
IROC's Avatar
Re-indexing torsion bars on an older car can turn into a nightmare. If your rear bars are the same as when it left the factory, this could be the pad in their labor quote.
Years ago (like, 17 years ago), I wanted to get my rear torsion bars replaced and most European auto shops refused to even do it claiming it was a nightmare. I ended up doing it myself and it was a nightmare. I even wrote an article for Excellence magazine about it...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-01-2011, 12:06 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
is that an estimate? or did they already do the work?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 06-01-2011, 12:10 PM
user & abuser
should be noted that i had already done the nightmare jobs of getting the old bars out and installing all new bushings
vini vidi vici
IROC's Avatar
Then the shop actually owed you money...
Mike
1976 Euro 911
Old 06-01-2011, 12:17 PM
WHO are you having to do this for you? I know several Good Places (one in Silver Spring and one near the Dulles Airport which is not cheap but I bet less than this. I also (Actually on 7th St NW as opposed to near DC in Maryland or Virginia) live in DC
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 06-01-2011, 12:19 PM
Follow me
seymore's Avatar
They had already started on the car and called me with about 20 other things they said I should do. I told them to please give me an estimate on the work I wanted done first and I would see how much futher I wanted them to go. They told me 4250 and I said I didnt want them going any futher. Im going to say something when I pay, If they want me back hopefully they will give me a break. Otherwise I need a new shop. Any Suggestions? Preferably nothing in Mcclean VA.
Iroc they told me 650 for the torsion bars.
1982 911SC
Old 06-01-2011, 12:24 PM
just me
paulgtr's Avatar
they didn't give you an estimate before the work was done?
Old 06-01-2011, 12:27 PM
ivangene's Avatar
if you did the T-bars why didnt you tackle the whole job...itys not THAT hard just takes time
Ed M
86' Coupe
Old 06-01-2011, 12:30 PM
r_towle's Avatar
these shops make profit on parts and dont make alot of money on labor.
If these guys are trying to make money, they would need to charge a higher rate for labor because they are no longer making any money on parts.
Its a business, not a hobby, and they have overhead costs to cover, bills to pay, insurance and lights to keep on etc etc.
I find it odd that anyone would assume that its ok to buy your own parts and bring them to a shop.
Seems like the same thing as buying grocieries at the store then going to a restaraunt and asking them to cook the raw goods for you, then complaining about how much it costs to sit there and eat your own food.
I am in no way trying to be rude, just stating the basic rules of business....they have an hourly rate that the shop must make to stay open...that rate includes not only labor, but also parts profits...together they make an hourly number.
You bring your own parts, the shop rate still is the same...so they charge you for it.
Rich
Follow me
seymore's Avatar
Rich,
All part were bought about a year ago with the intention of doing the job with father. He got sick my wife got pregnant and the parts sat. I cant return them and no longer have the time to wrench myself. What should I have done? Your telling me no shop should take my business because I bought the parts and if they do raise the rate? 4 thousand 2 hundred dollars keeps the lights and the doors open for a long time!
1982 911SC
Old 06-01-2011, 12:42 PM
Wash. State
nesslar's Avatar
How many mechanics make anywhere near $100/hour? Plenty of profit there.
I don't buy that, "You bring your own parts, the shop rate still is the same...so they charge you for it." They can try, but ain't happenin' to moi....
....the shop doesn't have to go out, look up, order, take in, or whatever, the parts; saves them a lot of time. Not to mention "prep/demolition/disassembly"... I've done this, no problem, just shop labor beyond that.
I'd just go elsewhere, (though too late, I gather), get an estimate for the labor and go for it. The labor described can't possibly be worth more than $2500-$3000 (if that), depending on hourly charge....
I'd b****; they owe ya.....
Old 06-01-2011, 12:46 PM
$4200 keeps the lights on at my house a long time too.
I dont see anything except maybe the rear bars that 2 men cant produce in a day at home and if it runs into Sunday, so be it.
When you insert the struts, do the bushings and the turbo tyrods and ball joints.
You havent accounted for the change of oil lines that is required on the heat boxes and the lines to the external thermostat that you might loose when you break them loose.
Once the exhaust is off, set the valves and change the plugs. Put the exhaust on and youre finished.
Bruce
Old 06-01-2011, 01:52 PM
kramer747's Avatar
Rich
This is dead on correct- we have to explain this to customers of ours all the time
Old 06-01-2011, 01:53 PM
just me
paulgtr's Avatar
you might have that policy at your shop, but that is not the point here. looks like the OP did not get an estimate first and is being taken for a ride...
Old 06-01-2011, 01:55 PM
