crashr's Avatar
3.2 Exhaust Leak Question
My Exhaust is leaking at the joint between the euro premuffler and the heat exchanger/crossover pipe. I have tried multiple times to torque the proper bolts down to the factory suggested torques, as well as a bit further to see if I could seal the leak. Nothing seems to help and it appears the contact point must be slightly warped and won't create a good seal. Is it possible to use two exhaust gaskets to create a thicker seal? Any other suggestions?
1975 Widebody 911 3.2 Euro
Old 07-09-2011, 08:43 PM
Yes. Or you can go to Napa Auto, get the thicker Fel Pro gasket material, and cut one out yourself.
Old 07-09-2011, 09:05 PM
RETIRED
Joe Bob's Avatar
Also check to see if the flanges are flat. Heat, flatten, file.....
2012 ML350 3.0 Turbo Diesel
Old 07-10-2011, 08:36 AM
Member 911 Anonymous
DRACO A5OG's Avatar
When cold, place a a mirror as JB stated to insure it is flat or as Russnak suggest a thicker Felpro Make a Gasket
'85 Carrera Targa
PCA/POC
Old 07-10-2011, 09:51 AM
crashr's Avatar
Any recommendations on which Felpro gaskets to get. I went on the site but I am not quite sure which ones I could cut to fit.
Old 07-17-2011, 01:17 PM
Gasket material comes in sheets of varying thickness. I made a gasket for my transmission. Just make sure that it can stand heat.
Old 07-17-2011, 03:02 PM
