Send a message via AIM to 82SC
Euro CIS vs US CIS
what are the different parts???
I am trying to maximize my car while staying smoggable...
I know the fuel distributor and the intake runners are different...I think the warm up regulator too...
what other parts would I need to change...
I have lots of leads on parts...but not many (affordable) entire sets...
MJ
Old 03-07-2002, 09:35 AM
wckrause's Avatar
The 82 US CIS was K-lambda and had the O2 sensor, frequency valve, and computer. The 82 ROW was still K-basic. It didn't run closed loop, so it didn't have all of that stuff. It used a different WUR, with two vacuum lines instead of one, and it also had a vacuum thermovalve.
The ROW CIS from 78-83 was much like the US 78-79 systems.
Exactly why do you want to go to a ROW system?
Bill Krause
We don't wonder where we're going or remember where we've been.
Old 03-07-2002, 10:17 AM
I'd like to know all the different parts myself.
My Automotion catolog, from a few years ago, lists the airbox for the Euro '78-'83 as the same as US '78-'79. But different than the US '80-'83. Not sure why, perhaps O2 sensor stuff.
Rob
1980SC Euro
Old 03-07-2002, 10:22 AM
I would like a list of parts that I would have to take off my CIS and parts I would have to obtain...and any mods I need...
I want the early CIS because I now have 3.2L heads so the intake porst are bigger...and the early CIS had the bigger intake runners...so I am trying to maximize flow while staying smog legal (no carbs)
if I can just swap the FD and the intake runners taht sounds like the easiest way...but I am wondering if there are other parts...
I guess the other way is to buy a 3.2L motronic harness...but that seems more expensive...and it is a hassle to install and I have to chip it...etc....
so I was going to stick with CIS...and try to maximize airflow
MJ
Old 03-07-2002, 10:26 AM
wckrause's Avatar
I don't think you can be smog legal with a Euro CIS system in CA. No EGR, no O2 sensor.
Maybe you can just use early or ROW intake runners and keep your FD.
Bill Krause
Old 03-07-2002, 10:38 AM
well I know people pass with SSI and their O2 sensor unplugged so I guess it is not that much of a priority for me...they just tune it lean for the test...
MJ
Old 03-07-2002, 10:42 AM
Hilbilly Deluxe
emcon5's Avatar
O2 sensor is listed as equipment for your car, so Goober at Smog-Pro should look for it, and it should fail the visual.
Now if Goober ain't bright enough to notice the cable isn't plugged into anything......
Tom
82 911SC Coupe
GTI Cup #43
Old 03-07-2002, 10:56 AM
BenWillis's Avatar
Send a message via ICQ to BenWillis Send a message via AIM to BenWillis Send a message via Yahoo to BenWillis
I just happen to have a complete working Euro CIS sytem that was removed from my 80SC this week to install my EFI conversion stuff...
I would part with it (whole shabang) for the right price...
Ben in SC
Looking for next project!!!
South East SCWDP Region, President
Old 03-07-2002, 11:02 AM
wckrause's Avatar
I assumed that when you said "smog legal", you meant smog legal.
Bill Krause
Metal Guru
911nut's Avatar
MJ,
You'll need the '78-80 airbox to go with your '78-80 intake runners in order to keep the diameter constant.
Old 03-07-2002, 11:30 AM
well when I said smog legal i ment smog "legal"
hahaha...
just for reference Steve at rennsport system just said that all I need to change is airbox, intake runner, FD, and WUR...
thanks...
MJ
Old 03-07-2002, 11:51 AM
