'70 911E
Hood latch releases over bumps
my 70E hood latch releases frequently over bumps, lubricated the latch mechanism and checked the cable, handle works smoothly and returns completely, does the pin wear out? Any ideas? thanks, Rick.
Old 06-23-2011, 01:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It may not be seating all the way. Check the height of the round bumpers, if too high, it may not allow the hook latch to seat all the way.
Can you post a pic with the lid closed compared to the side fenders?
'85 Carrera Targa
PCA/POC
Old 06-23-2011, 01:10 PM
'70 911E
thanks for your reply Draco, the hood and fenders fit up really flush, is there a length adjustment on the "pin" maybe I could lengthen it a bit.
Old 06-23-2011, 01:31 PM
DRACO A5OG's Avatar
Not sure about your year, i believe the base can be adjusted or the top hook latch can be moved over.
CAUTION, be careful not to lock yourself out. If too tight you may not be able to open it.
'85 Carrera Targa
PCA/POC
Old 06-23-2011, 01:38 PM
Been here a while
a couple of things....
if your suspension pan or chassis has 'some' rust, chassis flex can cause this....
also, (this did it for me) the latch has a safety mechanism built in, such that if the cable breaks, it will release the hood.....so, the reverse engineering solution means that if your cable is adjusted a smidge too tight or too loose, it can cause not enough grip to the pin.....best bet is to pull the latch and move the receptacle in and out on the cable to see when maximum grabbing occurs.....then adjust the cable accordingly.
Lewis
looking for 1972 911t motor XR584, S/N 6121622
Old 06-23-2011, 03:56 PM
This thread on the 912bbs sums up how to adjust it properly I believe:
912 Board - Viewing Topic: Re: Front Trunk Keeps popping open. Is it the latch or the release?
Scott
'78 SC mit Sportomatic - Sold
Old 06-23-2011, 04:15 PM
tobluforu's Avatar
This is almost just like adjusting the shift coupler. I went through the same thing, the top piece moves side to side, back and forth, and the screw in spring has to be just right. Also, if the cable is not setup just right, it will not bite enough. Takes time but you will get it.
Old 06-23-2011, 04:26 PM
PeteM1965's Avatar
I just fixed this on my 68. On the post attached to the hood loosen the large nut at the top, then using a screwdriver turn the post to lengthen it. Close hood and go for a ride on the bumpy road that pops your hood. If it pops you may need to lengthen it some more. It should remain tightly closed though, if the hood is loose then the problem may not lie in the post length. Then check the height of the rubber bumpers or the latch mechanism itself.
Good Luck
Old 06-23-2011, 06:27 PM
303462's Avatar
I had this same problem on my 71 911T. I changed out the latch , and then the pin assembly. Adjusted again and again. Was sure I had it right , and it would still pop open on the first good bump. Finally decided to replace the cable , since I had a new one handy, and then I could say I had replaced everything. When I pulled the old one out I found a slight kink in the cable about 2" below the T handle. Replaced it and I was fine. Think some one was feeding it in and met resistance when the cable end contacted the latch, then they tied to shove it in with pliers. Pretty frustrating, when you finish building a car , and then you can't keep the hood closed long enough to drive it. I feel your pain. Dave
Old 06-23-2011, 07:04 PM
'70 911E
thanks for all this help and advice, could have potentially made a mistake, will be working on it this weekend, I'll let you know how it goes.....
Old 06-24-2011, 07:09 AM
70S Targa Guy's Avatar
Location: A scenic and exhilarating drive along the Delaware River just one hour from Philadelphia, PA
Good Luck
+1 That is exactly how I adjusted mine with similar problem. Adjust a little bit at a time until desired results are achieved.
Old 06-24-2011, 07:11 AM
On my '70T, I did all the above and still ended up replacing the latch.. No more problems...
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-24-2011, 09:02 AM
Always learning
does this washer belong?
hmm.... I am having the same problem. The latch is centered.
Please see this image - i assume the washer doesn't belong? Thing is though when the washer is removed, the spring goes all the way down to the head - eliminating the small lip needed for the rod to engage. Any thoughts? Do i have the wrong spring? I have tried inverting it.
Hope this makes sense....
Old 07-17-2011, 11:16 PM
DRACO A5OG's Avatar
Brb, will post a 3.2 latch, it should be the same.
'85 Carrera Targa
PCA/POC
Old 07-17-2011, 11:19 PM
DRACO A5OG's Avatar
'85 Carrera Targa
PCA/POC
Old 07-17-2011, 11:23 PM
Always learning
mine is different
Hey Draco
always prompt with your replies... do you have a telepathic connection to this forum or something???
Thanks for the pic. I beleive my spring has a larger circumference. Although, thinking about it, it shouldnt make any difference.
Its damn frustrating though. Having to drive, stop, adjust, drive again....
Old 07-17-2011, 11:37 PM
DRACO A5OG's Avatar
LOL, Actually it is connected by IV
If I may suggest get rid of that washer and bushing/rubber (?) it should not be there.
Jim
'85 Carrera Targa
PCA/POC
Old 07-18-2011, 04:50 PM
