r_towle's Avatar
What types of G50's?
This is to learn.
What types of G50 transmission are there?
What is the short nose/long nose difference?
Are there gearing differences?
Rough cost of a used one?
Rich
Old 07-20-2011, 01:46 PM
AutoBahned
RWebb's Avatar
G50 is a class of trannies that replaced the 915 in (1988?)
they continued in use thru the 964 and 993
not sure re 996; I think P AG switched to the Japanese Aisen at some point in there (and I've worked hard to avoid learning much about the complicated modern cars like the SC...)
can you focus you question more?
Old 07-20-2011, 02:54 PM
They use Borg-Warner synchromesh, shift real good, take more torque and are heavy (compared to earlier designs).
In the 993 Porsche did a bunch of clever and expensive things to cut the weight some (like gun drilling at least one of the shafts).
What are you trying to pull off?
can't afford DSG
Old 07-20-2011, 03:15 PM
r_towle's Avatar
So there is one size, 5 speed G50?
88-98 is the same?
I am looking for the differences and types so that when I go shopping, I am educated.
Rich
Old 07-20-2011, 05:01 PM
Formerly known as Syzygy
Canada Kev's Avatar
G50s were introduced in 1987. There are a number of iterations. I believe the 964 'boxes are different from the 911s, but I don't know how, exactly. The 993 transmissions are longer than the 911s, though from what I understand are almost a direct bolt in on the 964 cars. From what I have been able to gather, there were three different factory G50s in the 1987-1989 cars: G50.00 (ROW), G50.01 (US, Canada and Japan) and G50.02 (Switzerland).
Kevin
Old 07-20-2011, 05:28 PM
Diss Member
Quicksilver's Avatar
The 87 through 89 G50s have a blunt end and the mounting is on the bottom.
The later cars starting with the 964s had a mounting ear on the end and are even longer.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-20-2011, 05:57 PM
CT Mike's Avatar
Quicksilver Pics are worth 1000 words. Nice going.
Old 07-20-2011, 06:52 PM
r_towle's Avatar
Thank you very much, the pics and all your knowledge answered my question.
So, what is the cost of a used 87-89 G50 on todays market?
I have no idea, have not seen more than one or two out there.
RIch
Old 07-20-2011, 09:31 PM
Rich, what year car do you own, and which engine?
Old 07-21-2011, 04:29 AM
Peter Zimmermann's Avatar
G 50 type 950/00 = Euro/RoW w/longer 4th & 5th ratios
G 50 type 950/01 = USA/Japan/M298 w/shorter 4th & 5th ratios
G 50 type 950/02 = Switz w/altered longer ratios (I believe this was done for quieter running).
G 50/03 = C2 Worldwide ratios
G 50/04 = C2 Switz only
*All above are 5-speed w/ 9:31 final drive
G 50/21 = 993 6-speed
G 50/50 = Turbo 5-speed used from 1989-1994
G 64 = C4 5-speed w/integrated transfer case
Keep the Shiny Side UP!
Pete Z.
Old 07-21-2011, 08:21 AM
redturbo911's Avatar
r-towle good question I learned from it as well thanks. pictures really are worth so much.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 07-21-2011, 08:34 AM
