ghamilton's Avatar
Magnecore vs OEM wires
My orig wires are looking pretty well, "original".
Mechanic say might be a good Idea to replace.
The OEM are really expensive.
What are your personal experiences with Magnecores? I had them on a couple other non P cars and liked them. Is the shielding really necessary?
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 07-21-2011, 09:28 AM
I don't have these myself, but I've heard good things about them and many racers use them. Shielding is not needed if you use spiral wound wires (I suspect Magnacores are spiral wound). I wouldn't hesitate to use them.
-Andy
Old 07-21-2011, 09:31 AM
Hendog's Avatar
I replaced my OEM with Magnecores. Good fit, no issues. I spent the extra money for that very reason.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 07-21-2011, 09:37 AM
porsher
aston@ultrasw.c's Avatar
no probs with magnecores here
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-21-2011, 09:47 AM
What does this mean?
"Mechanic say might be a good Idea to replace."
Did he explain why it might be a good idea?
Does the engine run well? Does it misfire? If okay, let it go.
or....
Might be a good idea to replace the coil too, and the ignition box, distributor cap and rotor, etc.
Sherwood
Old 07-21-2011, 09:55 AM
many here support/recommend Magacore, I have them, no issues, I expect they will last for a long time
Old 07-21-2011, 09:58 AM
8.8mm Magencors support several of my cars, strongly recommended.
Old 07-21-2011, 10:09 AM
Just to review some basics. Replacing good spark plug wires with a brand new set will not net you anything except a $200 debit in your checking/CC account. Has it been established the old set is kaput? YMMV for new red wires.
Shielding is to reduce/prevent electrical interference with on-board electronics.
Sherwood
Old 07-21-2011, 11:26 AM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
yes i agree completely. test the old ones before blindly replacing them. use your multimeter and test them all for continuity and resistance. examine the ends for corrosion and clean if necessary. check the insulation for cracking. lastly, i like to do a night-time throttle blip - if the insulation is compromised, you can actually see the sparks arcing across the engine bay and grounding wherever. it's quite a show.
but if they pass all these tests, there's no reason to replace them.
SOLD: '87 Carrera
Old 07-21-2011, 11:47 AM
i most cases i just fab up a set. $35 gets a 100ft roll of metal core belden wire and the crimp on ends are readily available. omh test the connectors for around 3K ohm resistance. 1K on the SC style distributor ends.
206 637 4071
Old 07-21-2011, 12:10 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I love my Magnecors, $200 bling in my engine bay , my OEM Berus were looking pretty worn so I pulled the trigger.
Check for errand sparks from the wires, in a garage in the dark, turn on the car and with a water bottle sprayer, spray a mist of water. If broken, you will see sparks, time to swap, if not fire your wrench.
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 12:12 PM
Originally Posted by lupin..the..3rd View Post
... lastly, i like to do a night-time throttle blip - if the insulation is compromised, you can actually see the sparks arcing across the engine bay and grounding wherever. it's quite a show.
Assuming you have a set of wires, but your engine is not running, so you can’t do the “running test” that you describe.
Is it possible to make a reasonable evaluation of the wires by measuring resistance and a CAREFUL examination of the insulation alone?
Old 07-21-2011, 12:15 PM
Yes. Fairly easy DIY project. If wire core is acceptable on your vehicle. Source some wire, connector ends and dist. cap boots. Practice your soldering skills.
FWIW, my stranded, stainless steel core, silicone-jacketed plug wires have been delivering spark to the plugs for over 20 years (knock on wood). Occasionally, I run a file over the soldered dist. cap ends to freshen the contact surface, then it's good to go. To reduce corrosion, some recommend using DOW 111 as an air insulator at the sealing junctions of the non-conductive joints.
BTW, introducing electrical resistance for radio reception using the built-in resistance of Beru spark plug connectors, resistor spark plugs and/or carbon-centered resistance wires (which are not repairable). Use minimum threshold resistance, if possible.
Since many use Magnacor or equiv. replacement wires in SCs and Carreras, may I assume electrical interference from non-shielded (braided) wire isn't a significant issue?
Sherwood
Old 07-21-2011, 12:50 PM
steely's Avatar
Magnecor (blue) here - I forget the diameter. no apparent shielding issues here - at least not on the FM stations I might listen to - although I have been listening less and less to the radio lately. I really needed to replace my cracked OEMs that were sadly still on the poor girl when I bought her a couple of years ago. I don't think they were the shielded type.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-21-2011, 01:50 PM
When my old wires turned out to be completely shot I replaced them with Clewett engineering wires. They are good quality and slightly lower priced if I remember correctly.
Good luck!
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner
Old 07-21-2011, 02:27 PM
DRACO A5OG's Avatar
Sherwood
I have aboslutely no interference from the magnecors on my 3.2
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 02:35 PM
LJ851's Avatar
What do you do when a connector is damaged or does not ohm correctly? Can these be bought separately, or do you get another used one?
Apologies if this seems like hijacking this thread, but my issue is similar to ghamiltons'. On my '72 I have Beru wires on the driver side bank of plugs and Belden wires on the passenger side bank of plugs (car came this way when I bought it). Today I found one Beru wire has a light blue powder on it (like oxidation) where it goes into the distributor cap, which is probably the cause of recent misfiring. I cleaned it up the best I could but some of it is still there. I am now thinking of replacing all 6 wires (plus the coil wire) since the mismatched brands and this one issue. The other wires seem fine (no cracking or cross-sparks). I have an opportunity to purchase some lightly used 8.5MM Magnecores. Any comments? Thanks.
1972 911 wide-body - gone but u never forget your first Porsche
Old 07-22-2011, 03:54 PM
Finally, a practical person. I was going to quietly exit this thread with a surprised look on my face, but this post is exactly what I have done, and probably would do again.
Old 07-22-2011, 04:02 PM
I've not read of this water spay method before.
Gotta try it now.
Old 07-22-2011, 04:03 PM
