 993 to 86 911 install parts delete question I am ready to stick my 1995 993 engine in my 88 911 and wonder which stock 993 parts I can eliminate without confusing the ECU.  Car does not have to be smoged as it is registered as a "collectible".  I'd appreciate any valid input since I don't want to create  problems by removing a do-hinckey or muffler bearing that the ECU wants to see. Thanks EP Slick - Tucson |
 Definitely lose the heater blower and sub a carbon fiber bypass tube for it. |
 theres not much too take off besides the cruise control and air pump assemblies. (as well as the air bypass tube as mentioned) |
 where are all the pics for this work?  c'mon this is cool stuff. is the 3.6 a turbo? |
 AC & bracketry(unless of course you retain AC) belt minder if changing to RS fan pulley most of the heat plumbing on the left side of the engine It will look like this http://forums.pelicanparts.com/uploa...1311368351.jpg Be sure to retain the vacuum canister |
 You mean if you pull all that stuff off, my fan and intake will turn orange??  cool!!! J/K :D |
 Vacuum line What is the purpose of this vacuum line?  I have found info referring to a "...rear shift valve assembly, solonoid (change over) valve installed for model year 1995..." Thanks EPS http://forums.pelicanparts.com/uploa...1311439009.jpg |
 its a vent line for the distributor. some models have two lines with one going to the rear reflector. |
 As RS mentioned on 993 there is another one that vents the 993 rear center tail light unit to prevent condensation |
 Keep #4 & #5 http://forums.pelicanparts.com/uploa...1311440514.jpg remove SAI and all associated parts http://forums.pelicanparts.com/uploa...1311440873.jpg |
 Thanks everyone Thanks everyone - certainly do appreciate the education. EPS |
 it should look like this http://forums.pelicanparts.com/uploa...1311612884.jpg |
 cam covers Yes, I have a pair of Patrick machined covers. Thanks EPS Quote:
| All times are GMT -8. The time now is 12:00 AM. |
