e p slick's Avatar
993 to 86 911 install parts delete question
I am ready to stick my 1995 993 engine in my 88 911 and wonder which stock 993 parts I can eliminate without confusing the ECU. Car does not have to be smoged as it is registered as a "collectible". I'd appreciate any valid input since I don't want to create problems by removing a do-hinckey or muffler bearing that the ECU wants to see.
EP Slick - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 07-21-2011, 01:09 PM
Rick Lee's Avatar
Definitely lose the heater blower and sub a carbon fiber bypass tube for it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-21-2011, 09:28 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
theres not much too take off besides the cruise control and air pump assemblies. (as well as the air bypass tube as mentioned)
Old 07-22-2011, 08:58 AM
FinallyGotOne's Avatar
where are all the pics for this work? c'mon this is cool stuff. is the 3.6 a turbo?
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 07-22-2011, 10:21 AM
Bill Verburg's Avatar
EP Slick - Tucson
SAI & all associated plumbing
AC & bracketry(unless of course you retain AC)
belt minder if changing to RS fan pulley
most of the heat plumbing on the left side of the engine
It will look like this
Be sure to retain the vacuum canister
Bill Verburg
Old 07-22-2011, 02:00 PM
rattlsnak's Avatar
You mean if you pull all that stuff off, my fan and intake will turn orange?? cool!!!
J/K
Old 07-22-2011, 10:20 PM
e p slick's Avatar
Vacuum line
What is the purpose of this vacuum line? I have found info referring to a
"...rear shift valve assembly, solonoid (change over) valve installed for model year 1995..."
EPS
Old 07-23-2011, 09:39 AM
rattlsnak's Avatar
its a vent line for the distributor. some models have two lines with one going to the rear reflector.
Old 07-23-2011, 09:44 AM
EPS
It's not a vacuum line, it is the distributor vent, there is a low pressure stream of fresh air that is directed into the distributor to prolong belt life, 964 before '93 did not have it oem, partway thru '93 it became standard w/ a retrofit kit for earlier cars
As RS mentioned on 993 there is another one that vents the 993 rear center tail light unit to prevent condensation
Bill Verburg
Old 07-23-2011, 09:54 AM
EPS
that is referring to the solenoid used to operate the intake manifold resonance flap, as i mentioned you want to keep the vacuum canister located under the aire filter housing and the associated vacuum lines.
Keep #4 & #5
remove SAI and all associated parts
Bill Verburg
Old 07-23-2011, 10:08 AM
e p slick's Avatar
Thanks everyone
Thanks everyone - certainly do appreciate the education.
EPS
Old 07-23-2011, 10:33 AM
e p slick's Avatar
Old 07-25-2011, 08:46 AM
No, you do want to leave the cam cover though
it should look like this
Bill Verburg
Old 07-25-2011, 09:55 AM
e p slick's Avatar
cam covers
Yes, I have a pair of Patrick machined covers.
EPS
Old 07-25-2011, 03:49 PM
