Hendog's Avatar
torque spec for brake light switch
I've searched and looked in my Bentley but cannot find the torque spec for the two brake light switches on the M/C. Does anyone know or is it just "tighten until it's tight and go"?
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 07-21-2011, 08:03 PM
Member 911 Anonymous
DRACO A5OG's Avatar
11 ft lb, Brother! In the Bentley towards the back of the section.
Remember use a piece of 2X4X24 to press the pedal about 1-2 inches to help keep the air out of the system and drop some fluid into the new switches.
Jim
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 09:21 PM
Hendog's Avatar
Jim
I used more than 11 ft lbs to tighten and I did fill them first before putting them in. What page/section Draco did you find that torque spec? I'm searching and still haven't found it.
460-11 is 11 ft lbs for wheel bearing lock nut.
figure 971-8 situates the switches but doesn't give a torque spec...
Henri
Old 07-21-2011, 09:59 PM
DRACO A5OG's Avatar
470-10.
If I may suggest, place a piece of paper towel around the switches with a rubber band to insure you have not over torqued it. Check after couple of runs and some hard braking.
Jim
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 10:06 PM
Hendog's Avatar
I'm not too concerned. It took a bears' amount of torque just to break them loose, then more than 11 ft lbs in my guesstimation to remove them over a couple of revolutions at first. They screw in very tight all the way through.
I appreciate the spec and page location.
Thank you.
Henri
Old 07-21-2011, 10:13 PM
DRACO A5OG's Avatar
Roger That!
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 10:14 PM
