-   -   81 911sc MSD Install Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/62064-81-911sc-msd-install-problem.html)
mdanna 03-08-2002 12:54 PM
I have purchased a MSD 6AL. After installing it as per 101 projects and tech article I have no spark. If I connect the green magnetic pickup wire to the Violet and ground to black coming from the MSD unit It fires right up but runs at 2000RPM. I have checked everything according to MSD. White wire creates spark after touching to ground. I have the adapter "no change". I put the old CD unit in and it runs fine.
WHAT AM I MISSING????????
Anyone have this problem? MSD support was no help.
mdanna 03-13-2002 06:50 PM
Problem solved.... Directions show polarity reversed on the Mag pickup. New set of Fyrebraid wires, NGK plugs and the MSD. Purrrs like a Lion :)
