Porsche Crest '72 911 - Front End Height Adjustment
When looking at my '72 911 the right side, drivers side is about 1" lower than the left side. What do I need to adjust so I can correct the height difference? All help is appreciated. I am new at this!
Dean
Old 09-05-2011, 04:10 PM
Oh Haha's Avatar
There are screw-in adjusters to raise/lower the front. My concern would be WHY is the DS so much lower? If anything, it should be a bit higher if the car has been corner balanced and aligned.
You can raise the DS using the screw but you will most likely mess up the handling as you will now affect the PS rear.
What are the rear side to side measurements?
Pacific Blue
Wayne
Old 09-05-2011, 04:45 PM
haycait911's Avatar
you'll also need an alignment after messing with the height. best do the complete car and corner balance if you wish. then get it aligned.
Old 09-05-2011, 06:28 PM
