-   -   Headlight seal (http://forums.pelicanparts.com/porsche-911-technical-forum/620907-headlight-seal.html)
Chris78 01-05-2024 05:32 AM
Originally Posted by Stimorolgum (Post 12088459)
The headlights are not original and the bezel just won't fit.
I bought a new bezel and it fits, but only without the rubber seal.
Maybe some aftermarket seals are harder than other. Unfortunately I threw the old one away, stupid mistake.
I will try to figure this out. Fortunately I live in a dry climate and my car never touches rain or wet roads.
I wonder if others skip the rubber seal, can't see it on some pictures on the internet.
My top tab was fairly worn down and I couldn't get the bezels to stay with the seals so I have mounted them without any. I will maybe try the vw seals but for now works fine. YEMV
kevbo 01-06-2024 01:41 PM
Originally Posted by kevbo (Post 12164690)
Restarting this thread since I'm working in the same area and have a question. I'm changing the H4 glass from clear to amber and there is a rubber gasket around the glass itself. The original rubber gasket needs to be replaced and I need new ones for the new glass. Here's a pic:
http://forums.pelicanparts.com/uploa...1704456557.jpg
I thought it was this part (911-631-115-02) but it's the gasket shown in the above thread but it's not the right part.
http://forums.pelicanparts.com/uploa...1704456735.jpg
Any advice would be much appreciated,
Any ideas on this rubber trim on the glass itself?
MSL212 07-27-2024 09:43 PM
This is an old thread, but it was right on. I ended up using the idea of sewing the joint together to give it added strength and used the tape idea to help stretch it around. I trimmed the top where the rim hooks on to allow it to grip better.
At least now i will have a good nights sleep!
The instructions should come with the part.
Marc
