225 Tire Width NOT the Same???
OK, guys, I don't get it, I have 225's in front. I went from Goodyear F1 GS-D3's to Continental Extreme Contact DW's.
What's up with the apparent width variance. Is one manufactuer's 225 smaller the other's 225's. http://img.photobucket.com/albums/v5...724_130255.jpg F1's http://img.photobucket.com/albums/v5...724_130313.jpg DW's I always felt the Conti's were skinner at the tread but until I blew my tire and waiting for the replacement I had installed my spare F1's. Now it is definite. TIA, JIm |
Eagle F1 GS-D3 I don't see any 225 size of this tire in Tirerack. ??
Yes, all tires vary. This is why tire rack for example lists tread width in the tire specs. Some tires are almost a different size than what they are labeled.
Annoying, Live and Learn :eek:
that's annoying. have you used a tape measure to get the actual tread measurement? Would be interesting to know the difference.
Copy that, will measure and post when my replacements arrive.
They vary greatly between manufacturers
Because they can......
Is that the front tire? It looks like its turned out a bit more on the first pic???
Oh no, First is the Driver side and the 2nd is passenger side. my attempt to show the same angle.
The goodyear is definitely more square then the conti's |
Just looks like the Conti has a more pronounced rim protector at the bead. I bet if you measure the actual tread width that the G'yr is wider.
The Conti's have greater rim protection. The tread contact patch is the same. The tire's sidewall construction is setup differently. I loved my last set of Contisports and really wanted the DWs but couldn't find them in 16's. I eventually had to buy a set of tires so I went with Yokohamas but I'd go back to Continentals in a NY second.
I really like them too, very quite and once broken in sticks pretty well.
Yes
Well, I'll see when I do the Road Hazard Exchange :eek:
Well to my dismay the Conti's 225 are skinner than the Goodyear 225's.
http://img.photobucket.com/albums/v5...729_170222.jpg That really sucks big donkey dix :Eek: |
They very greatly btw manufacturers also as pictured the tread patch varies as does the patch to side wall radius which controls a lot of what we are looking for in width.
You can use a couple of straight edges on tire width to then measure the theoretical width (225) it will also show the radius on the tire and how far from the max tire width the tread really starts to make contact. Definately sucks, need a place you can see a lot of different tires on our cars to help decide what to pick. Good luck |
| All times are GMT -8. The time now is 10:46 PM. |
