-   -   Port Hole in My SC Trunk? Is this Correct??? (http://forums.pelicanparts.com/porsche-911-technical-forum/621295-port-hole-my-sc-trunk-correct.html)
mercury26 07-25-2011 08:36 PM
Port Hole in My SC Trunk? Is this Correct??? Mystery, Solved? :)
I pulled the carpet out of my trunk to get some other work done (read rusty battery tray). I noticed the following "port hole" in my trunk but it does not seem right. The item in question is on the passenger side, towards the front of the car under the jack. Does something else go here? A rubber grommet? Something else? Or is this correct?
UPDATE: After verifying that the "mystery item" was not needed. I pulled it off and found no hole or anything else. It was a metal tin type thing (2" x 3") that was siliconed to the car. One of the bizarre things you find in used cars. I have no idea why it was there or what it was for. At least it was not covering some kind of damage or hidden "goody". I guess the rust gremlins lost their door in and out of my trunk. :)
http://forums.pelicanparts.com/uploa...1311654938.jpg
DRACO A5OG 07-25-2011 08:43 PM
Well, I just check my 3.2 it does not have that port under the Jack holder mount.
mercury26 07-25-2011 08:44 PM
What do you have there? Just sheet metal?
DRACO A5OG 07-25-2011 08:51 PM
Just sheet metal. Even you bolt there does not look OEM. Is that oil near at the bottom?
mercury26 07-25-2011 08:53 PM
I have oil and crud in my trunk. Not sure where it came from, as I just got the car.
DRACO A5OG 07-25-2011 08:55 PM
I would not worry about it, it seems to be sealed well.
mercury26 07-25-2011 08:57 PM
I am not worried, but getting other body work done up front. If it is not supposed to be there, then I will have them seal it up with sheet metal and paint. :)
Thanks,
Chuck
DRACO A5OG 07-25-2011 08:59 PM
Cool.
mercury26 07-26-2011 06:28 AM
Looking for more opinions....
Barrpete 07-26-2011 06:35 AM
What's on the other side? Are you sure there's a hole or did a PO just stick that on there with a bunch of RTV for some obscure reason?
javadog 07-26-2011 06:45 AM
Not needed, not supposed to be there.
JR
mercury26 07-26-2011 06:47 AM
JR
Thanks! I will dig in and see what is there. If there is a hole in the sheet metal (which I think there is) then I will have the body shop repair.
Thanks,
Chuck
Vereeken 07-26-2011 07:50 AM
Cablemechanism to front trunk snapped and PO made an access hole to release the lever, then figured that it might happen again and made an escape hatch?
The headlamp washer pump went tits up and PO was lazy and instead of dissasembling everything in the wheel whell he decided to cut a maintenance hole?
Michel
mercury26 07-26-2011 08:00 AM
Michel
Hole is on the passenger side, the cable and washer pump are on the driver's side. Try again. :)
Jerome74911S 07-26-2011 08:06 AM
Looks like a sardine can to me.
mercury26 07-26-2011 08:09 AM
Yes, does look like one. But pretty small, maybe 2 inches width and 3 inches height (at most).
Thanks,
Chuck
MBruns 07-26-2011 09:04 AM
air hole
That looks like the inlet hole for the front condenser fan that has been blocked off, hard to tell from that photo exactly where it is.
Mike Bruns
javadog 07-26-2011 09:12 AM
Mike Bruns
Wrong spot for that. The hole looks to be on the right side of the car, unless I'm looking at it wrong.
JR
mercury26 07-26-2011 09:15 AM
JR
You are correct, as I stated in the initial post:
"The item in question is on the passenger side, towards the front of the car under the jack"
Thanks,
Chuck
skunked 07-26-2011 09:58 AM
My SC does not have anything like that....
maybe it's a Blinker Fluid Reservoir ;)
