How to remove label from DME cover?
Hi,
hoping to tap the collective wisdom of the board - and yes I did search and didn't quite find what I was looking for. I recently replaced the cover on the Motronic (DME) of my '95 993 with a new one, because the old one had a few broken tabs (long story). I would very much like to transfer the sticker, that has not only the exact Porsche part number but also the Bosch part number on it, from the old cover to the new cover. During the early days of the 993, Porsche revised the DME several times, so knowing the exact part numbers is essential. Unlike the VIN sticker on the door jamb, this sticker is smaller and has no perforations that could lead to tears. I am currently away from home but I can post pics when I get home. What are my options? I came up with the list below. My overriding concern in all of these to keep the sticker intact - i.e. no cuts and no discoloration. 1) heat gun and razor - cons: seems easy to cut the sticker up 2) bake in oven @ ~ 150 deg to soften the glue and then try to slide the sticker off - cons: sticker may discolor 3) label remover in a can - no experience with such products. I have heard suggestions as varied as starting spray and WD40 4) get a copy of the original sticker made - what kind of business can make duplicate metal film stickers? Ideas much appreciated. Thanks /alex
-- alex -- I SWEAR: Forget Porsches - Lifted, fully kitted, gray Sprinter Vans seem to be THE NEW midlife crisis vehicles for rich people! Why??? Large wallet != very rugged |
1988 Carrera
Alex:
What is the sticker made of? If it's some sort of plastic/paper you could try a wet cloth heated in the microwave. Heat the cloth lay it over the sticker, let it sit a while, reheat the cloth and so on. Back in 79 the decal on the fender by the gas fill, unleaded fuel only, was remover this was. Bill |
Formerly known as Syzygy
I recommend that whatever method you try, to take some good detail photos of the labels, perhaps with a small ruler visible for scale. If all fails with the removal and you really bugger the thing up, you could always make a replacement. Take the pics to a vinyl sign/decal cutter and they should be able to print you a new one (or reasonable facsimile) on vinyl with a Gerber Edge or similar equipment.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Good advice. I will take some pics, with a ruler in the picture and get a backup sticker made.
Platinum Member
Cut out the metal, drill 4 holes in the corners, and pop rivet it on the new cover?
