Bumper Heating Up
I have an 87 911 and after the oil burned off from the car sitting all winter, I noticed the bumper was extremely hot... and ideas could be causing this to happen?
Old 07-27-2011, 08:26 PM
steely's Avatar
Welcome!
Is your muffler/exhaust system stock? because it's pretty much right behind the bumper - were you letting it idle in place or driving her around?
Show us a pic of your car when you get a chance.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-27-2011, 08:43 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Welcome aboard!
+1 Bumper hot when car hot, normal.
Put your hand near the driver rear wheel, even hotter with the cat.
'85 Carrera Targa
PCA/POC
Old 07-27-2011, 08:54 PM
Danny_Ocean's Avatar
I hate to be the guy who says "do a search", but there are a few good threads already on how to insulate the rear bumper (typically to protect paint).
Old 07-27-2011, 08:59 PM
Thanks for the feedback... I did do a search on "over heat, hot bumper... and several others and did not find anything. Bottom line is, just don't touch it. If it hasn't effected the paint
Old 07-28-2011, 05:47 AM
what a great ass!
Old 07-28-2011, 05:48 AM
Taking it apart is easy
Jerome74911S's Avatar
You have to remember that the bumper is thick aluminum. It soaks up heat easily and fast.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-28-2011, 08:13 AM
Make Bruins Great Again
Por_sha911's Avatar
I've seen where an improperly installed rear valance (or aftermarket exhaust) will cause the muffler to come in contact with the rear valance (thanks for screwing up my car "Doc"). There should be a small air gap. Without air flowing around the muffler the heat builds up and you can damage the paint.
Joe
Old 07-29-2011, 09:30 AM
Mo money = mo parts
Do you have the shield in place between your exhaust and your bumper? It's part number 930 505 511 00 "Heat Protection" in the catalog. I am sure some heat will still get transferred, but if you are missing the shield it might be hotter than others are experiencing. I don't recall my rear bumper being an issue, I will check next time the car is out.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 07-29-2011, 09:38 AM
DG624's Avatar
You can have the CAT and muffler ceramic coated to reduce heat by 20%.
Old 07-29-2011, 11:31 AM
Once a friend of Cliff
juanbenae's Avatar
along with your net worth
Old 07-29-2011, 02:32 PM
rfloz's Avatar
Have you considered a little ventilation?
Bob F.
1984 Carrera Factory Turbo-Look
Old 07-30-2011, 10:10 AM
jderrick's Avatar
The following photo courtesy of Bill Verburg - Extra Cooling Air-holes On Deck Lid
Old 07-30-2011, 02:57 PM
rfloz's Avatar
Oh,right, get all holier than thou.
Seriously, I did the holes because my car was getting hotter than I liked while waiting in line for auto-x runs. I have a small battery and don't trust it to start the car multiple times (we get 12 runs and with unloading off the trailer, tech, etc., that's maybe 20 starts and very little re-charging). Any way, it seems to help.
And, more to the point, the bumper is cooler (okay, it is fiberglass) and I have had no paint damage around the pipes.
Just a couple of 4" holes behind the license plate might help if you want to stay stockish.
Bob F.
Old 07-30-2011, 04:22 PM
My bumper is fiberglas...
Melting Fiberglass Bumpers?
Old 07-30-2011, 08:08 PM
rfloz's Avatar
I went to TRE for the installation of my fiberglass bumper. So, yes, they put some insulation on as per the referenced thread. No issues to date.
Thanks, Dave.
Bob F.
Old 07-31-2011, 09:45 AM
