tanmanbgoh's Avatar
timing chain question
Im a newbie and the more I drive my 1985 targa,the more I think we will eventually get married. But,how good is the timing chain on a car with 160,000 miles with no way to tell if it was ever replaced. It was a 2 owner california car that was repoed to third owner who sold it to me.He never drove it,it was in a garage for 2 years.No docs on car,but everything seems very good so far(knock,knock)What are chances it was replaced?? Slim? or prolly?? thanks
Old 07-30-2011, 10:12 AM
tanmanbgoh's Avatar
Sorry, how strong are those chains compared to belts?? thanks
Old 07-30-2011, 10:13 AM
kodioneill's Avatar
You can check for wear by removing one of the chain covers then you can inspect the chain, tensioners and rails. Not a difficult job at all. Replacing them is a different story.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 07-30-2011, 10:18 AM
belts need frequent replacing in comparison, at 160k miles if that is what they have the components are likely due for replacement at least a good check. you don't want to have the cam timing get messed up while the engine is running,
if checking look for master link, if found then they are not the originals, doesn't mean they haven't been replaced however, the chains and other parts there can be replaced without pulling the engine completely out, maybe just dropped a bit or left in place, it can be involved if e.g. cam timing needs checking/etc. My 2 cents, others here know infinitely more. It is all doable if you get help here and are patient.
Old 07-30-2011, 10:58 AM
If the chains are worn out, its time for a build..you can paint it any way you want but its time for a build.
Bruce
Old 07-30-2011, 11:37 AM
Bruce
agreed, good point
Old 07-30-2011, 01:05 PM
