Suspension Refresh Review
Greetings,
I am in the middle of a suspension refresh. I am mostly looking for feedback in the way of “did I miss something” or “that configuration/combo will not work. I have a 1976 911S with about 110k miles on it. The engine is stock with a MSD and Pertronix Ignition. I have lowered the car to Euro specs and upgraded to 16x6 and 16x7 Fuchs. The suspension with the exception of the upgrades I have done is stock. Here is a list of parts that I am installing: FRONT: Turbo Tie Rods – TTK-930N Turbo Tie Rod Wrench – PEL-SR2201 Monoball Strut Mount Set Camber Plates – PEL-TE-MSMS911 Rebel Racing Products Front Bushing Set – PEL-RSR-FRBSH Ball Joint – 911-341-049-01-M69 Cotter Pin – N-021-521-1-OEM Lock Plate – 901-341-426-00-M260 Nut for Ball Joint – 901-341-425-00-M260 Threaded Pin for Ball Joint – 911-341-119-06-M260 Washer for Threaded Pin – 900-089-006-01-OEM Lock Nut for Threaded Pin – 999-084-019-02-M100 Ball Joint Wrench – PEL-TOL-P210 Front Sway Bar Bushing – 911-343-792-03-M260 Rennline Truss Mount Strut Bar – REN-SB809193-SI ** I have a set of 21mm torsion Bars to install, as part of the suspension refresh. I have Koni Adjustable shocks currently installed. REAR: Elephant Racing Weather-Sealed Monoball Cartridge – ERMP-2020901 18mm Rear Sway Bar Bushing – 911-333-793-02-M260 ** I already installed a set of Adjustable Sway-Away Spring plates and 27mm Torsion Bars with Bilstein Sport Shocks. Any feed back would be greatly appreciated before I pull the trigger and order the parts. Thanks! Gary
Max Sluiter
You will love the RSR bushings. Make sure you push the front housing and A-arm all the way back into the tightened rear mount before you torque the front one. This makes sure there is no axial play that can cause a slight, one-time "tick" when you back out of the garage. There is no harm in this condition, however.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
