Question Weber carb calibration for 3.0
Hi all,
I'm trying to figure out how to set up my Webers (40 IDA 3C).
I just got them the other day and started to look at them today. They are in need of a rebuild and calibration for my engine, so that is my next project.
Here is what they came with: 30 chokes, 55 idle jets, F26 emulsion tubes (some missing), no main jets (all missing).
I have to buy some emulsion tubes and main jets at a minimum so I'd like to get everything I need in one order.
Warren mentioned that Bruce Anderson's recommendations are for a 3.0 with carbs and a hot cam. I was going to go with BA's recommendation, but since I am going to run a stock cam and pistons, I do not know what I should buy for a good baseline setup. Anyone have any thoughts?
Wayne - does Pelican sell calibrated Weber carburetor parts? If not, who should I get them from (Pierce Manifolds, PMO, Rennsport Systems)?
Thanks for any thoughts.
Thanks!
Charlie
More info: '79 SC 3.0 / Weber 40 IDA 3C carbs / SSI heat exchangers/ stock 72 exhaust / stock cams / stock p&c / stock ignition
Old 07-19-2001, 08:34 AM
