-   -   if you could build "The Ultimate" A/C system from scratch... (http://forums.pelicanparts.com/porsche-911-technical-forum/622224-if-you-could-build-ultimate-c-system-scratch.html)
WERKD e28 07-31-2011 04:56 PM
my heads spinning from all the chatter & posts on this topic...
my SC came without A/C and definetly needs it in Atlanta weather.
If you could build the most effective / powerful setup...
Who's:
condensers
evaporators
blowers
etc would you mix & match to get the best results ?
It seems a few guys are doing this well, but the posts suggest some would like to use a different blower,or another manufacturer's condenser, or...
Joeaksa 07-31-2011 05:30 PM
The newest condensors on the market seem to be made by a gent on this forum.
http://forums.pelicanparts.com/porsche-911-technical-forum/617196-i-make-parallel-flow-micro-channel-condensers-911s-front-rear.html
The above is the latest thread. There are people out there who insist that you buy everything from them, but then they want mega $$$ for the stuff. You can do just as well by buying the stuff for your system unless you need everything.
RSTarga 07-31-2011 05:34 PM
If money were no object. I'd go with those new micro channel condensors. Griffin's Kuehl fan and evaporator with the variable speed controler. And i'd have aluminum lines made up like in the 964 and later cars to reduce the amount of hoses.... In a perfect world.
jackb911 07-31-2011 06:13 PM
Hey, Steve,
If I was starting from scratch on a 911 that never had A/C, I'd explore using one of those Vintage Air mini systems that are designed for street rods, except I would use a 993 front mounted condenser. These condensers came with an integral fan.
I'm not a thermodynamics expert (although I took a semester of it in college) but it seems incredibly dumb to mount a condenser above the hot engine as in the stock location, or beside the catalytic convertor or pre-muffler as in the very pricey Griffiths/Kuehl upgrade.
The first 911's that had decent factory A/C were the 964's and 993's. Both had a small condenser behind the left headlight.
While I haven't seen an running example, it would seem that a creative fabricator could come up with a viable, affordable A/C system using the Vintage Air components. I've owned and ridden in street rods with their systems that generated serious, ice cold air. Here's their site: Vintage Air - Inventors of Performance Air Conditioning - www.vintageair.com
If these guys came up with an affordable, workable kit for pre-1990 911's, they would make a fortune.
Here is another place that is a good source for "build it yourself" A/C components:
Southern Air - Street Rod Air Conditioning - Southern Rods and Parts
Nick Triesch 07-31-2011 07:52 PM
The best way to start from scratch with a new A/C unit is to sell your car and buy a clean 993! Really great A/C! Most bugs worked out! Nick
88911coupe 07-31-2011 08:11 PM
What's annoying as hell to me is that any piece of crap sold in the last 20 years has solid a/c...we don't need some ultimate state of the art system in 911s...I just want want what you could have gotten in any 20 year old Toyota at the time. Actually, the pathetic level of AC in our 911s is a little embarrassing, and I don't care about the stories we tell ourselves we we "keeping it real" back in the day.
Joeaksa 07-31-2011 08:22 PM
Jack911,
Good comments but one thing.
Please do not recommend the 993 condensor in the fender! If you like this, and I do, please recommend the "993 STYLE condensor" in the front fender. Problem is that the old 993 condensors are going on 20 year old technology and the newer versions are FAR superior in many ways.
Agree with the concept and useage, just do it with newer products to get better results in the temp drop.
Joe A
scotricker 07-31-2011 08:27 PM
subscribed!
Me too, no factory AC ever, need to figure out what to build.
Porchcar guy 07-31-2011 09:00 PM
Guys, it seems to me that if you buy a "Kit" from one of the big 3 Porsche A/C companies, you will spend somewhere between $2000 and $2800 for the works...Compressor, front and rear condenser, evaporator + valve, drier, dash vents and barrier hoses. I have been exploring the internet trying to find alternatives...buy the hoses and fittings from a company and have a local guy mate them...Sanden 507 compressor from ebay ...condensers from another internet company and some other places to get things a bit cheaper. No complete answer yet but I think it can be done for less and as good...it ain't rocket science...just long dirty work to complete. JM2C
Kidasters 07-31-2011 09:06 PM
You've got the best advice - buy a 993.
I just had the whole A/C system re-done in my car. My mechanic said "you know, this will never be as good as a modern car".
No matter what you do - it will never be as good as a modern car.....
Ken
WERKD e28 08-01-2011 05:04 AM
i would buy a 993 if it was in the budget...
i have to "make do" with what i have (an SC), and want to do this RIGHT the 1st time.
appreciate everyone's input ! very useful !
Pyregrine 08-01-2011 06:34 AM
I'm interested as well! We have a 1966 with no a/c and in 100 degree heat... yuck!
My husband's a mechanic, so we're gathering all information we can before we start this project :)
wwest 08-01-2011 09:45 AM
Someone should disassemble one of those Home Depot, Costco, <$500 10,000+ BTU portable air conditioners and see if there is a "fit". ~1000 watts at 120 VAC but 2000 Watt MSD inverters have gotten pretty cheap.
sc_rufctr 08-01-2011 09:54 AM
Actually that's not a bad idea but you'd still need an auto spec compressor for the engine bay... Unless you went full electric only. Hmm :)
BGCarrera32 08-01-2011 11:09 AM
What makes even less sense is mounting 3 or 4 large muffin fans under the engine lid condenser, to "move more air", and then running them in reverse whereby they take hot air from the hot engine compartment and blow it over the hot air exchanger (condenser) and out to ambient. All while the engine is drawing air into the engine compartment across the condenser for intake and cooling. So muffin fans fighting intake and the alternator fan...
Figure that one out.
zippy_gg 08-01-2011 11:18 AM
I was under the impression that these fans were "pulling" and not "pushing" so they actually draw air from the outside through the condenser, which would make a lot more sense.:confused:
BGCarrera32 08-01-2011 11:30 AM
Yes- but the install I refer to had them running the other way, as if the guy wired the fans with backwards polarity...:rolleyes:
quattrorunner 08-01-2011 11:34 AM
sub
wwest 08-01-2011 02:34 PM
Most modern "muffin" fans are brushless and therefore not reversible.
Where did you see/find one of these mods with the muffin fans exhausting air upwards...?
kramer747 08-01-2011 06:41 PM
I'm sorry to be a downer -factory ac in 911's has never been good and aftermarket stuff is not much better. Again, sorry
tirwin 08-01-2011 09:25 PM
I've got an '83 triple black SC with no working A/C. It can get hotter than two cats humping in a wool sock driving it around in the summer. System hasn't been converted to 134. Has the original York compressor. It is totally empty of refrigerant right now. Switch needs to be replaced. It seems the 134 conversion is a complete waste of time and money, so I've been contemplating one of the aftermarket options (including the new parallel flow condensers in the other thread).
Talked to a local shop to get some ideas. They recommended the RetroAir system. Said they just did a complete system for another customer with an '85 and parts and labor came out close to $4k. As Shaggy would say... "Zoiks!"
I'm still trying to figure out exactly what would be required.
The RetroAir system includes:
- Evaporator
- Condensor (multi-flow)
- Drier with hi/lo switch
- New center dash vents
- Barrier hose
Then I'd have to add new compressor. Blower upgrade is another extra. All that is $1800 in parts alone. That's a lot of coin. Might just have to continue living with my 2/80 A/C system.
wwest 08-01-2011 10:13 PM
- Evaporator
- Barrier hose
IMMHO there is really only one design problem with the factory A/C, not enough heat exchanger capability. But we do need to address the issue of the need to annually top off the refrigerant level.
So I would start out converting to R134, but include a new dryer/rcvr, a hi/lo pressure switch, and 2 12 volt 2" thick 9" fans mounted inside the engine compartment to pull airlow down through the condensor even with the engine idling.
Assuming, as you say, you'd be starting out with an EMPTY system, all the above work could be DIY...<$300 even including the A/C specialist time for pump down and R134 installation.
I'd even bet that with the above modifications the front condensor blower could be tossed, and maybe also the condensor itself.
See:
http://forums.pelicanparts.com/porsche-911-technical-forum/622453-loss-refrigerant-theory.html
KelogGes 08-03-2011 07:49 AM
sometimes you need to think outside the box
welll I would not say "ALL AFTERMARKET STUFF IS NOT MUCH BETTER" he he he
open your minds read and learn about something NEW designed for Porsche aftermarket
I make "PATENT PENDING" Parallel Flow Micro-Channel Condensers http://forums.pelicanparts.com/porsche-911-technical-forum/617196-i-make-parallel-flow-micro-channel-condensers-911s-front-rear.html
wwest 08-03-2011 08:13 AM
"..sometimes you need to think outside box..."
IMMHO you have needlessly designed and build "better" condensors when the OEM ones are more than adequate when considered one against one, yours against "theirs".
Obviously you are aware that the primary shortcoming is in the lack of the ability to convert ENOUGH HIGH pressure refrigerant GAS into a liquid state.
So, is the OEM condensor at fault...?
No.
The inability to more enough airflow over the condensor vanes is the problem, not the condensor itself in any way.
But, hey, using your "specialty" condensor in the rear deck lid position, do you NOT recommend adding blowers/fans along with...?
If not, that makes you the "goat" of the day (decade??), even Porsche knew that forcing more airflow over the condensor would improve system efficiency.
So why not try the blower/fans first and if that doesn't result in adequate cooling, rapid cabin cooldown rate, then start throwing money into the winds.
wwest 08-03-2011 08:17 AM
I recently read somewhere that in later air-cooled engine models Porsche used a technique to help cool the engine, engine compartment, once the ignition was off and/if the compartment temperature rose to too high a level.
Turned on the cabin heater blower.
True..?
Was this to protect the engine or was it to prevent the A/C from over-pressuring the o-rings, etc,....??
WERKD e28 08-03-2011 02:29 PM
if i see another post for these parallel universe contoured condensors...i might have to buy one.
now---what else ?
electric fans attached to said condensors
who's blower
who's evaporators
who's condensor
again...the Ultimate System !
vulcan300 08-03-2011 03:16 PM
This is an interesting unit for DIY electric cars. At 500W through an inverter it might work. The price is nice too.
Electric Vehicle Airconditioner
patssle 08-03-2011 03:23 PM
Except that you'll need ~40 amps at 12 volts.
I have a hairbrained idea for heat/cold in my 914. An electric compressor with the condensor and evaporator both in the rear trunk and the air flow in a hose that runs through the engine bay and firewall - and switch that hose between the evap. and cond. as the seasons change. A 2nd hose to exhaust the other air through the floor of the trunk.
With a 2nd battery up front that would require plugin charge overnight, it could power it for at least an hour or two.
Just an idea for now.
vulcan300 08-03-2011 03:32 PM
Yes, the zero after the 12 is rather important. My engineering professors would be disappointed in me!
hcoles 08-03-2011 03:39 PM
hair brained idea #x
small flap set around the rear condenser with actuator(s), when AC set to max. flaps better seal the condenser against the deck lid, when not set to max. engine gets cooler air and makes the front condenser take up the slack, this could be made light weight I'll bet
