1968 911L F Value
I bought this 911 l and I'm trying to decide if i paint it and replace a few parts. Any idea of value on this. 1968 L with a 1972 911E motor, 5 speed, Rust is the battery tray. a little surface rust showing through a few spots. it has the S trim on the interior and exterior, rear sway bar. I dont want to get upside down. Thanks
15 Cayman 93 Amethyst 964 Cab & 67 21 window VW Wife's 64 356 69 912 targa 68 911L Hot Rod |
Well, a 68 L was all 911S except the motor. The L motor was a 2.0 with an airpump on the left chain cover and a long nose to drive it on the cam. For asthetics, you should find an L motor, they are available.
Bruce |
If you want to maximize value, with SWB prices going the way they seem to be going you should look for a 911L motor and work towards authenticity. A recent Excellence buyers guide had SWB values and market prices that might help you.
On the other hand, my 68T is heavily modified, has a 72 2.4MFI engine, and is an absolute _blast_ to drive and enjoy... |
Max Sluiter
Just fix it up and drive it. The motor you have is much better than the original.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I've got a '68 with a 70E motor in it. Must have been common to swap the 2.0 for a 2.2 engine.
Are your door pockets original? They look a bit different from mine, but I do have a '68 normal instead of a '68L. --Von
Von Whitley Los Alamos, NM |
Rotmikly - I think you're right....My 69 has a 71 2.2 motor.......Must have been more plentiful back in the day...........
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
PM sent
The basketweave is interesting, especially on the rear panels.......I thought all 68L's had elephant hide.
My base 68 911 has basketweave on seats and front door panels but smooth on rear area.... |
not sure if the door pockets are original or not. Thy look like they are. the have the same metal trim as the top trim piece does.
Are your door pockets original? They look a bit different from mine, but I do have a '68 normal instead of a '68L. --Von i need to find that copy, it seems to be the only one i dont have. If you want to maximize value, with SWB prices going the way they seem to be going you should look for a 911L motor and work towards authenticity. A recent Excellence buyers guide had SWB values and market prices that might help you. The basketweave is interesting, especially on the rear panels.......I thought all 68L's had elephant hide. im not too familiar with the L model I agree with the 72 motor it will drive a lot nicer.
