2 Wires Cylinder Heat Temperature sensor vs the single wire one
What is the difference between the 2 (beside the wire numbers) and if the 2 wire is the new type, when was it introduce? Since mine is a conversion fitted with the 2 wire one, the introduction date may give me a reference date for the conversion. Thanks JJ |
The 1 wire sensor grounds through the body of the sensor, the 2 wire switch grounds through the second wire (more reliable)
1 question down, 1 more to go (introduction date)... |
| All times are GMT -8. The time now is 07:54 PM. |
