83 911 Production Cab #10
JJ 911SC's Avatar
Question 2 Wires Cylinder Heat Temperature sensor vs the single wire one
Originally Posted by syncroid View Post
The new head temp sensor is a two wire sensor. The old one is a single wire.
OK a search yield the above.
What is the difference between the 2 (beside the wire numbers) and if the 2 wire is the new type, when was it introduce?
Since mine is a conversion fitted with the 2 wire one, the introduction date may give me a reference date for the conversion.
JJ
Who Will Live... Will See
Old 08-02-2011, 02:43 PM
LJ851's Avatar
The 1 wire sensor grounds through the body of the sensor, the 2 wire switch grounds through the second wire (more reliable)
Old 08-02-2011, 04:13 PM
JJ 911SC's Avatar
1 question down, 1 more to go (introduction date)...
Old 08-02-2011, 04:17 PM
